:cry:
Ok I'm getting the spiderman vcd in bare format tommorow. And I've heard the entire copy can span to 2 gigs. How will i be able to convert the whole movie on VCDs? Or SVCD
Expand more on what you mean by bare VCD format?
o(-_-)o---------------------------------------o(-_-)o -
HOPE THIS CAN HELP, I just reburnt it to a VCD!
CONVERTING SPIDERMAN SVCD 3 CDS into 2 CD VCD.
OF course you could just DL the new rip but if you cant find it, try this.......
I extracted the AVSEQ01.MPEG (also known as DAT maybe which is a MPEG2 for SVCD) of Spiderman with ISOBuster.
Then I took the AVSEQ01.MPEG and used TMPGEnc to make it into a Video-CD, NTSC which is 352x240 and 29.97 FPS.
That took about an hour to do on each AVSEQ01.MPEG for each CD. So now I had 3 AVSEQ01.MPEG's (I named each different like SpideyCD1, then CD2 and CD3.) I then went to TMPGEnc again and merched all 3 MPEGs together. That took acouple minutes too. Then I had a full 1.15 GIG Spiderman VCD 352x240 that ran in Real Player and Windows Media perfect.
Then with that, I split it into 2 Cds but cutting it where Norman Osbourne is in Harry's apparentment, right before that where its just a screen of the streets and building. Cause I hate when they rip it right in the middle of a speech someone's giving.
Then I had SpideyCD1.mpeg and SpideyCD2.mpeg and used VCDEasy to convert that back to a BIN file. That took a minute. Then I just burnt with Goldenhawk Technology CDRWIN and it came out fine.
NOTE: I tried do this with NERO and it did not work for some reason. I made several coasters, hopefully this helps others out! Have fun, great movie.
Special thanks to the MexedOUTRicer for help on this. HAHA Laters. -
What I meant was. The CD has multiple files in formats that have to be converted to .RAR then Bin/Cue Then MPEG. The Solution was posted before but the thing is, CDRWIN doesnt work with my burner. I'll keep researching to find another wayOriginally Posted by neffs
Joining and Chapters
By nomis66 in forum MacReplies: 19Last Post: 17th Jul 2008, 14:18 -
By nomis66 in forum ffmpegX general discussionReplies: 1Last Post: 14th Jul 2008, 20:29 -
joining in vegas
By sabrinimartini in forum EditingReplies: 4Last Post: 27th Mar 2008, 08:43 -
Joining
By breeze9 in forum EditingReplies: 2Last Post: 30th Dec 2007, 16:14 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 01:23
