VLC v 3.0.18 'Vetinari' Win 11 desktop. nvidia 1070 running two monitors
With preferences at default, opening VLC by double clicking certain mp4 videos causes VLC to open too big for one screen and spreads across two. But it is only certain videos, not all, but all are mp4
It is fine if I run a video from an open VLC.
But it does not remember the last window/size if I set it first then close with 'x'
I have played with numerous settings but none are effective.
Any suggestions welcome, thank you.
I would suggest:
a. try latest nightly (https://nightlies.videolan.org/)
b. report issue to developers (https://www.videolan.org/support/#bugs)users currently on my ignore list: deadrats, Stears555, marcorocchini -
I tried the mosdt recent nightly but just the same so will send a bug report. But odd I'm the only one! Thank you.
bwallx,
Here's my work around.
Works for both single and dual monitors.
First, VLC is set as the default program for your file type. You are going to change one Option from the default Preferences. VLC version 3.0.18
1) Double-click the file you want to play with VLC. VLC opens and starts playing the file.
2) Tools > Preferences > Show settings > switch from Simple to All (at the bottom left)
3) Click, Video (left side)
4) Scroll all the way down on Right side
5) Change "Zoom video" from 1.00 to whatever size you like using the little Up/Down arrows. You can also highlight then type a value into the box.
6) Save
7) Close VLC
Now when you double-click a VLC associated filename, VLC opens in a scaled window based on the percentage you set under Zoom video... and it remembers
creakndale
PotPlayer Window Not Maximizing Across 4 Monitors
By rae@sewaustin.com in forum Software PlayingReplies: 0Last Post: 21st Sep 2022, 13:40 -
Is it just me or are new monitors have more matte texture than 2010s era?
By Knightmessenger in forum ComputerReplies: 11Last Post: 10th Apr 2021, 17:31 -
Monitors for casual gamers
By Rostin in forum ComputerReplies: 0Last Post: 10th Mar 2020, 05:40 -
How to Expand PotPlayer to all monitors???
By potato502 in forum Software PlayingReplies: 3Last Post: 21st Jul 2019, 14:02 -
MPEG 2 Extension for VLC? (VLC can't play its own recordings?!?!)
By gastrof in forum Newbie / General discussionsReplies: 17Last Post: 17th Dec 2018, 00:06
