Salut!
I got the following problem: I want to make a VCD out of a DivX file. I have a DivX File with a framerate of 23,976. I used VirtualDub for the audio and then encoded it with TEMPGenc (like it is described on the mainpage...). But when I switch the Framerate to 25Fps the mpeg file got little "stops". I tried to encoded the file with only 23,976Fps but my DVD-Player can't handle it (there is just a black and white screen and the CD won't start). Does anybody understand my problem and knows how to solve it??? Please help me, this had cost me my whole day argh!!!
your source file is in NTSCfilm format, and you're trying to encode to PAL format. you have to convert between the formats first. search the forums for NTSC to PAL conversion--you should find something usefulOriginally Posted by JimHimself
or try this
http://forum.vcdhelp.com/viewtopic.php?t=78178
its not simple so be prepared for some hard work!
MKV with Variable Framerate convert to MP4 problem
By beaniekapp in forum Video ConversionReplies: 12Last Post: 4th Jul 2010, 08:44 -
HELP - MKV reference framerate change problem
By danielo in forum Video ConversionReplies: 5Last Post: 20th Aug 2009, 06:22 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 17:14 -
Framerate problem when muxing
By baconharvester in forum EditingReplies: 3Last Post: 17th Sep 2007, 18:35 -
converting framerate problem
By Shaorin in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 00:00
