Hello
Still trying to get to the bottom of why some of my purchased DVDS playback so badly, slow jerky and awful ??
yet other when ripped playback as if they were in a normal DVD player
Albeit DVD quality is so bad anyway on todays HD Screens
but why have some of my DVDs I have purchased been mastered so they playback so bad, jeryky frame rates etc
They play back bad in VLC player and also on my zidoo HD3000 £1000 media player, yet other DVDs playback as expected
So below are two DVD info files, the first one plays back as expected and the second plays back jerky and blurry
so lets see what the difference is ??
Good DVD RIP
General
Unique ID : 330230707062913201276033788375575516925 (0xF8701EE81637FC03C53E422BA02756FD)
Complete name : H:\Video\JNM_BCHI\B1_t00.mkv
Format : Matroska
Format version : Version 2
File size : 1.31 GiB
Duration : 28 min 51 s
Overall bit rate : 6 518 kb/s
Encoded date : UTC 2023-03-12 15:27:06
Writing application : MakeMKV v1.17.3 win(x64-release)
Writing library : libmakemkv v1.17.3 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Format settings, picture structure : Frame
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Bit rate mode : Variable
Bit rate : 6 000 kb/s
Maximum bit rate : 8 000 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.579
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Closed
Stream size : 1.21 GiB (92%)
Language : English
Default : No
Forced : No
Original source medium : DVD-Video
Audio #1
ID in the original source medium : 189 (0xBD)128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 52.8 MiB (4%)
Title : Stereo
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
ID in the original source medium : 189 (0xBD)129 (0x81)
Format : AC-3
Codec ID : A_AC3
Bit rate : 256 kb/s
Title : Stereo
Language : English
Default : No
Forced : No
BAD DVD RIP
eneral
Unique ID : 170242542811870396692302720590706653811 (0x80138566E00BFE43687C3D0673143A73)
Complete name : H:\Video\Man About The House S1\Man About The HouseS01E01.mkv
Format : Matroska
File size : 996 MiB
Duration : 24 min 53 s
Overall bit rate mode : Constant
Overall bit rate : 5 597 kb/s
Encoded date : UTC 2023-03-12 14:56:37
Video
Format : MPEG Video
Format settings : BVOP
Format settings, Matrix : Default
Format settings, GOP : M=2, N=5
Format settings, picture structure : Field
Codec ID : V_MPEG2
Bit rate : 5 400 kb/s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.521
Time code of first frame : 09:59:59:20
GOP, Open/Closed : Open
Stream size : 961 MiB (96%)
Language : English
Default : No
Forced : No
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B/G
Matrix coefficients : BT.470 System B/G
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Delay relative to video : 24 ms
Stream size : 34.2 MiB (3%)
Title : Stereo
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Chapter 02
00:06:05.400 : en:Chapter 03
00:12:45.200 : en:Chapter 04
00:15:07.800 : en:Chapter 05
00:21:51.000 : en:Chapter 06
So what is the difference as to why one would playback bad and the other DVD to playback fine ??
the main thing I have noticed is
is the good one is Format settings, picture structure : Frame
and the bad one is
could this be why the software and hardware players playback differently ??
also could the bad Format settings, picture structure : Field, remuxed to frame if this is the reason
why would the DVD original mastering use frame / field ???
what is the difference??
thanks for any info, as this is really bugging me as I have many purchased DVDs that playback real bad when ripped ??
Hope i am getting close to the problems
regards
