Hi, I've been using Staxrip successfully to deinterlace some old avi files before editing in Resolve. I've some more recent HDV footage which is in .m2t files from a Canon HV40 at 1440x1080. What is the ideal format for doing the deinterlace for this source format? I used ProRes MOV files for my avi footage based on a Youtube video recommendation but no doing this for much higher resolution source files generates massive file sizes. Is there any recommendation I should use for target format, without doing much compression before editing? This is for personal/informal use but just trying to do things in a proper way.
				Results 1 to 10 of 10
	I've been reviewing this and noticed in Staxrip that the ProRes profile was set to 422 HQ which is probably way overkill for this HDV source footage.
 Is there any other format I should be considering as an "editing format" that I can import into Resolve other than ProRes? I will in the end render to H264/265 mp4.
	You could use Prores Standard, or LT (light) if you wanted smaller filesizes / lower quality
	I will explore the different options with ProRes. Is ProRes the best option I should use for an intermediate format?
 I'm also capturing a lot of analog into HuffYUV encoded avi files. I'm assuming I cannot deinterlace and output to this same format, so should I consider anything other than ProRes to import into my editing software?
	Not sure, I don't really use either - I use the backend tools directly like avisynth, vapoursynth, ffmpeg
 It sounds like you're trying to deinterlace the HDV (probably with QTGMC ?) , then import into Resolve ? They should be both ok for that task
	Yes, my sources will be either M2T HDV or Huffyuv AVI, will deinterlace, crop, add borders, denoise and whatever else with some of these tools, then import that file into Resolve and then deliver to something like H265 MP4 for YouTube mostly. Still learning and trying to nail down the workflow.
	Another question on this process... Staxrip used to deinterlace HDV m2t files from an HV40 camera. The only action set up in Staxrip is the deinterlace. I notice that the audio format is set to mp2 by default - this doesn't give me any audio in Resolve. It is fine playing the files in something like VLC player.
 After loading my file this is what I see in the audio section:
 MP2 2ch 48kHz 384Kbps (File-0047 PID 814 L2 2ch 48 384 DELAY 0ms.mp2)
 What is the rationale behind the mp2 default here, and should I be changing this to a different format like aac or mp3 in the options?
 If I leave things as per default I see the following in mediainfo...
 Format : MPEG-4
 Format profile : QuickTime
 Codec ID : qt 0000.02 (qt )
 File size : 2.10 GiB
 Duration : 1 min 44 s
 Overall bit rate : 172 Mb/s
 Frame rate : 50.000 FPS
 Writing application : Lavf59.20.101
 Video
 Format : ProRes
 Format version : Version 0
 Format profile : 422
 Codec ID : apcn
 Bit rate mode : Variable
 Bit rate : 172 Mb/s
 Width : 1 440 pixels
 Height : 1 080 pixels
 Display aspect ratio : 16:9
 Frame rate mode : Constant
 Color space : YUV
 Chroma subsampling : 4:2:2
 Scan type : Progressive
 Bits/(Pixel*Frame) : 2.208
 Stream size : 2.09 GiB (100%)
 Writing library : fmpg
 Audio
 Format : .mp2
 Codec ID : .mp2
 Bit rate mode : Constant
 Bit rate : 384 kb/s
 Channel(s) : 2 channels
 Channel layout : L R
 Sampling rate : 48.0 kHz
 Stream size : 4.80 MiB (0%)
 Default : Yes
 Alternate group : 1
	It's probably stream copying the original audio . You should use uncompressed audio in MOV for Resolve
  Deinterlace or not?By leed17 in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2022, 18:42
  deinterlace helpBy maudit in forum Newbie / General discussionsReplies: 7Last Post: 13th May 2022, 23:40
  Compress DVI AVI files without having to deinterlaceBy Trucknotmonkey in forum Newbie / General discussionsReplies: 10Last Post: 11th Sep 2020, 08:03
  How do I convert a .m2t file to DV-AVI and keep date/time codes?By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Mar 2019, 15:41
  Quality loss in captured HDV m2t files with respect to HDMIBy kassim in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2018, 17:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
