Hey... does anyone know if the venturer STS-32AAs can play DVDr's and copied VCD's/CD's... I've already put on the region hack & i'm wondering if there's anything else I can do...
I just got a CD burner & want to know if my DVD player plays my copied CDs or if it's also MP3 compliant, as I saw a version of the same model with MP3 capability... Is this a secret function that i've not yet unlocked?
Any info on this thing would be well appreciated as I didn't get a manual with it.
Thanx in advance.
ThEeDaRkOnE.![]()
I also have a venturer system. I have a dru500a DVD writer. I have tried Memorex DVD-RW(mp3 files), imation DVD+RW(mp3 files) TDK DVD-R's (mp3 files) and none of these work. I burned them with Nero 5.5.17 and CDcreator all worked on pc but not my Venturer STS32-M. I even took them to Circuit City(store) and tried them on a Sony and they did not work. However, they work in a PC with DVD drive.
CD-R's with VCD and MP3's all seem to work.
Question: Have you had any luck with running DVD with the Venturer?If you can't change the things around you then change your reaction to the things around you. -
It seems as though there are only a few brands of DVD-R that work in this machine, likewise CD-R's... I found that datasafe 24X disks seem to work for MP3's & VCD's, Likewise the 24 Speed Diskwrite CD-R's, Unfortunately there seems to be very little in the DVD-R market that the laser seems to pick up... You can hear the machine trying it's best to find the Track Zero, but after a while, it says "disk not found". Thinking in getting shot of this machine... The onboard Amp is the only thing its got going for it...
Durabrand STS 9800 Region Free code
By jfreak53 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Sep 2011, 20:48 -
Venturer PVS-1371 cannot play back up dvd
By Geninq in forum DVD & Blu-ray PlayersReplies: 8Last Post: 7th Jun 2011, 00:31 -
Sts-131
By redwudz in forum TestReplies: 1Last Post: 7th Apr 2010, 02:25 -
DVD hack request for venturer PLV71198S20
By tigers66 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jan 2009, 11:12 -
Venturer sts 75e problem after unlock Region Code
By Chon-ji in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th May 2008, 23:00
