Why my Lg oled TV (2016) doesn't properly read mkv files from an external Hard Disk anymore? Several mkv videos, along the whole video, get stuck for a few seconds, then I get a halo/drop of pixels, like a pixels waterfall before the video continues. I tried using an external media player (MYPIN 4k video player) but the problem persists (minus the pixels halo). Even VLC on my Mac has troubles playing (not all but some) of these mkvs. For the record: the mkvs are movies and tv series I get from torrents. Any help is much appreciated! Thanks!
Sound like a dying external hdd,...
users currently on my ignore list: deadrats, Stears555, marcorocchini -
for hetch54, not every torrent is illegal.
Actually the external hdd is brand new... -
New or old, any storage device can have issues. Check SMART on your drive. If you're on Windows, I recommend CrystalDiskInfo. If anything is yellow or red, your drive is bad and prepare a replacement.
Read the manual for what types of videos are supported by your TV. Container (e.g. .MP4, .MKV, AVI, etc.) is unlikely the issue in your case since the videos play, but format, video/audio is probably your issue. The built in media player, no matter how expensive the TV, is very limited compared to an external player.
Check and compare the video/audio format of your bad files against ones that play correctly. If you're lucky, it may just be incompatible audio.
Ultimately the best answer is to get a $50-100 external media player like an Android box* that will play many more files than any built-in media player.
*Here's a good thread about Android boxes https://forum.videohelp.com/threads/386414-Android-Box -
Thanks for your reply!
After several attempts I realized that some videos got somehow damaged in the transfer/copy from my iMac to the external hard disk.
Mkv videos that would play well and smoothly in VLC on my mac, would not anymore after I pasted them in the hdd, and I played them with the same computer (iMac) and software (VLC) but wouldn't work properly (either they get frozen, hiccup, pixels dropping or VLC would crash), so I guess the issue is from one device to another, some datas get lost in the transfer. -
Good to hear you solved the issue.
I don't know what software to use on a Mac, but always verify your copy after you're done.
Is there a player that can read external subs?
By Patapin in forum DVD & Blu-ray PlayersReplies: 12Last Post: 20th Dec 2024, 12:38 -
VHS doesn't work properly
By vhs-help in forum Newbie / General discussionsReplies: 7Last Post: 7th Dec 2020, 00:04 -
MP4Box as external muxer in Virtualdub doesn't produce a file
By wout25 in forum Newbie / General discussionsReplies: 12Last Post: 14th Oct 2020, 13:14 -
Nero doesn't link with external device
By BabyDaddy in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2020, 07:51 -
Multiple MKV files required to be in same folder to play properly
By AgKwo in forum Video ConversionReplies: 4Last Post: 8th May 2020, 07:34
