I have an avi file thats about 105MB. I have the audio file thats about 490MB (from VirtualDub) and when I use TMPGEnc to make a mpeg, the file is about 750MB. it really sucks because if I'd have to make the VCD 3 CDs long. is this normal? is there a way to reduce the file size? thanx
Results 1 to 9 of 9
if the file is 750mb after the TMPGEnc porcess it will fit on 2 cd's not 3 /
2 is standard for VCDo(-_-)o---------------------------------------o(-_-)o -
How long is the movie? You can put 80 min of video in vcd format on 80 min cd-r. 1 min mpeg 1 video = 10 Mb file size.
May the force be with you. -
Yes, Tbear is correct. If you have encoded EXACTLY to VCD standards, you can fit approx 76 minutes on 1 disc. If it is to spec's pay no attention to the file size. Again, I must stress, if it is to specification.
ntsc = 1150 kbps cbr mpg 1 vid X 224 kbps mp1 layer 2 audio stereo~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Are these lines normal?
By Abas-Avara in forum Newbie / General discussionsReplies: 12Last Post: 18th Oct 2009, 11:41 -
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 00:36 -
Normal encoding
By mrgorgeous in forum ffmpegX general discussionReplies: 4Last Post: 5th Oct 2008, 17:42 -
vegas - is this normal?
By wingfan in forum Authoring (DVD)Replies: 9Last Post: 18th Jul 2008, 08:52 -
Is this normal for SUPER?
By ryphlex in forum Video ConversionReplies: 2Last Post: 17th Jul 2007, 14:27
