Hey!
I got the DVD of Rockman: Hoshi ni Negai o (a.k.a Mega Man: Upon a Star in america), however it is interlaced. What is the best way to deinterlace today?
Here is the video file information:
General
Complete name : C:\Video\MEGAMAN_SCN\A1_t02.mkv
Format : Matroska
Format version : Version 2
File size : 1.27 GiB
Duration : 28 min 32 s
Overall bit rate : 6 363 kb/s
Encoded date : UTC 2023-03-05 05:26:55
Writing application : MakeMKV v1.17.2 win(x64-release)
Writing library : libmakemkv v1.17.2 (1.3.10/1.5.2) win(x64-release)
Video
Format : MPEG Video
Format profile : Main
Format level : Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Format settings, picture structure : Frame
Codec ID : V_MPEG2
Bit rate mode : Variable
Bit rate : 5 973 kb/s
Maximum bit rate : 8 000 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.577
Time code of first frame : 01:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Closed
Stream size : 1.19 GiB (94%)
Language : English
Default : No
Forced : No
Original source medium : DVD-Video
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 10 of 10
It's probably hard telecined and isn't pure interlace, only encoded as interlaced. If so, you want to IVTC it and not deinterlace it. The best way to IVTC it is within an AviSynth script.
But that's probably not quite what you had in mind. Next time, maybe don't ask for the 'best'.
And converting it to an MKV isn't such a good idea if the source is a DVD. You create a D2V file from the VOBs using DGIndex so that D2V can be opened in an AviSynth script using MPEG2Source.
You should probably upload a 10 second untouched sample. You can cut one out of a VOB using DGIndex. -
IVTC. Use avisynth and not virtualdub for it. also use the mpeg2cut2 instead of mkv file making
mkvs sometimes f##k up when when imported while the same does not happen with VOB/MPG files -
Understood. Here goes the sample cuted with DGIndex.
You could try: QTGMC + Spotless + DeHalo_Aloha + SelectEvery(clip, cycle=10, offsets=[0, 5])
For the fun of it I attached a clip and here's the Vapoursynth script used https://pastebin.com/fuQGzeKN to create it.
I added a bunch of other filters for cleanup, the steps for deinterlacing I used are the once mentioned above.
Cu SelurLast edited by Selur; 8th Mar 2023 at 12:13.
users currently on my ignore list: deadrats, Stears555 -
Why do anything to it? Just watch it. Do you think it will look better after you do all these things?
It's better to QTGMC to 59.94 fps and SRestore to 23.975.
at least here sRestore to 23.976 still keeps some of the blends.
So the best solution would probably be to either:
a. live with the blends and 23.976 fps
b. go for 11.988 and then interpolate to 23.976 using RIFE or similar
c. create vfr content.
Ps.: attached an example when using QTGMC_SelectEvery_RIFE + some filteringLast edited by Selur; 9th Mar 2023 at 02:51.
need help about deinterlacing.
By paijo in forum Video ConversionReplies: 6Last Post: 25th Aug 2022, 13:08 -
Problem with deinterlacing NTSC DVD probably made from PAL TV Show
By citroenfan in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2022, 11:57 -
Find Photos on DVD and Xmedia Deinterlacing
By b-dubs in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2022, 08:43 -
Deinterlacing DVD source while preserving the maximum quality possible.
By dopethrone in forum Newbie / General discussionsReplies: 24Last Post: 19th Feb 2022, 23:54 -
Deinterlacing DVD with Handbrake results in minor stuttering
By StevoLopata in forum Video ConversionReplies: 2Last Post: 3rd May 2020, 10:22
