Hi,
I've been using an AviSynth+ script without any errors for 2 years.
However, since February 2023, it has been increasing the video length a lot. For example, a 2-hour video is being delivered as a 4-hour video.
Interestingly enough, I have noticed that this problem of doubling the video length does not occur in videos shorter than 1 hour.
I "guess" that it's not the AviSynth+ script that's causing the issue, but rather a Windows update on my Windows 10.
I'm using LSMASHVideoSource to open the file in AviSynth+.
Please,
Does anyone know why it is happening?
Have you faced a similar problem?
More details about my PC features, Windows data, and AviSynth+ Script are available below:
Device Name: Tony-PC
Processor: AMD Ryzen 7 2700 Eight-Core Processor 3.20 GHz
Installed RAM: 64.0 GB
Device ID: C34E00E7-08DA-4E24-9800-FB393CD66A3C
Product ID: 00331-20020-00000-AA561
System Type: 64-bit operating system, x64-based processor
Pen and Touch: No pen or touch input is available for this display.
Operating System Name: Microsoft Windows 10 Pro
Version: 10.0.19044 Build 19044
Other Operating System Description: Not available
Operating System Manufacturer: Microsoft Corporation
System Name: TONY-PC
System Manufacturer: System manufacturer
System Model: System Product Name
System Type: x64-based PC
System SKU: SKU
Processor: AMD Ryzen 7 2700 Eight-Core Processor, 3200 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date: American Megatrends Inc. 2407, 01/07/2020
SMBIOS Version: 3.2
Embedded Controller Version: 255.255
BIOS Mode: Legacy
BaseBoard Manufacturer: ASUSTeK COMPUTER INC.
BaseBoard Product: TUF GAMING X570-PLUS_BR
BaseBoard Version: Rev X.0x
Platform Role: Desktop
Secure Boot State: Unsupported
PCR7 Configuration: Binding Not Possible
Windows Directory: C:\Windows
System Directory: C:\Windows\system32
Boot Device: \Device\HarddiskVolume4
Hardware Abstraction Layer: Version = "10.0.19041.2251"
User Name: Tony-PC\Tony
Time Zone: Brasilia Time
Installed Physical Memory (RAM): 64.0 GB
Total Physical Memory: 63.9 GB
Available Physical Memory: 55.3 GB
Total Virtual Memory: 63.9 GB
Available Virtual Memory: 53.1 GB
Page File Space: 0 bytes
Kernel DMA Protection: Off
Virtualization-based security: Not enabled
Device Encryption Support: Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Virtualization Enabled in Firmware: No
Second Level Address Translation (SLAT) extensions: Yes
Virtualization Enabled: No
Data Execution Prevention Available: Yes
AviSynth+ SCRIPT THAT I'M USING:
Code:SetMemoryMax(1024) SetFilterMTMode("MT_SERIALIZED", 3) Loadplugin("m:\temp2\mvtools2.dll") LoadPlugin("m:\temp2\CNR2_x64.dll") LoadPlugin("M:\Temp2\LSMASHSource.dll") LoadPlugin("M:\Temp2\RgTools.dll") LoadPlugin("M:\Temp2\MPEG2DecPlus64.dll") Import("M:\Temp2\Zs_RF_Shared.avsi") Import("M:\Temp2\LSFMod.avsi") Import("M:\Temp2\SetMTMode.avsi") ####Source=mpeg2source("D:\Paulo Medeiros Junior 19-7-18\dvd\17 dvd e 09 8mm.d2v") ####Source=AVISource("D:\Bolshoi\Lote 02\L02-18 4capt V7800LGPANSVHDMI c TBC Ok.avi") ####Source=DirectShowSource("D:\Valdir Steglich 21.2.22\08 Valdir vhs V17JVCES10 Ok.m2t") v = LSMASHVideoSource("D:\Bolshoi\Lote 02\L02-45 2capt V19LGPANSVHDMI.mp4", track=0, threads=0, seek_mode=0, \ seek_threshold=10, dr=False, fpsnum=0, fpsden=1, \ format="YUV420P8", decoder="", prefer_hw=0, ff_loglevel=0) a = LSmashAudioSource("D:\Bolshoi\Lote 02\L02-45 2capt V19LGPANSVHDMI.mp4") Source=AudioDub(v,a) #Source=DirectShowSource("E:\Carol 18.11.20 - Fazer\03 CA V17JVCES10.mp4", fps = 25, ConvertFPS = True ) #.Crop(0,0-0,-30,true) # para AVI encapsulado AVI Xvid da Avermidia #Source=DirectShowSource ("E:\Pricilla 3.9.20 - Fazer CM\01 PR V17JVCES10.mp4", fps = 25, ConvertFPS = True ) ##Source=DirectShowSource("E:\Decio 1.3.21 - Fazer\02 Decio 6 capt VPAN2JVCES10DV.avi") SetFilterMTMode("DEFAULT_MT_MODE", 2) #Conditionalmedian(source,mthres=16,mwidth=7,mheight=5,mp=11,interlaced=true) #ConditionalDenoise(source,mthres=16,mwidth=7,mheight=5,mp=11,p1=24,p2=12,interlaced=true) #bob(0,0.5) chroma=source.Cnr2("oxx",8,16,191,100,255,32,255,false) #VHS output=MDegrain2i2(chroma,8,2,0) stackhorizontal(source,output) return output #------------------------------- function MDegrain2i2(clip source, int "blksize", int "overlap", int "dct") { Vshift=0 # 2 lines per bobbed-field per tape generation (PAL); original=2; copy=4 etc Hshift=0 # determine experimentally overlap=default(overlap,4) # overlap value (0 to 4 for blksize=8) dct=default(dct,0) # use dct=1 for clip with light flicker fields=source.SeparateFields() # separate by fields #This line gets rid of vertical chroma halo. Don't use unless you have the problem #fields=MergeChroma(fields,crop(fields,Hshift,Vshift,0,0).addborders(0,0,Hshift,Vshift)) super = fields.MSuper(pel=2, sharp=1) backward_vec2 = super.MAnalyse(isb = true, delta = 2, blksize=blksize, overlap=overlap, dct=dct) forward_vec2 = super.MAnalyse(isb = false, delta = 2, blksize=blksize, overlap=overlap, dct=dct) backward_vec4 = super.MAnalyse(isb = true, delta = 4, blksize=blksize, overlap=overlap, dct=dct) forward_vec4 = super.MAnalyse(isb = false, delta = 4, blksize=blksize, overlap=overlap, dct=dct) #Increase thSAD for more denoising. Won't do much beyone about 1500 MDegrain2(fields,super, backward_vec2,forward_vec2,backward_vec4,forward_vec4,thSAD=1500) Prefetch(16) Weave() }
Thank you so much!
Results 1 to 9 of 9
The script itself looks fine and doesn't change the length here at all.
My guess is either the time codes of your input are broken or audio is way longer than the video.
So, I would suggest to try:
a. remuxing the file while dropping the time stamps and processing the new file.
b. only processing the video and check the output length.
c. try using LWLibavVideoSource instead of LSMASHVideoSource
Cu Selurusers currently on my ignore list: deadrats, Stears555 -
Hi Selur, I followed your recommendation and made the following change to my script:
Code:v = LWLibavVideoSource("D:\Bolshoi\Lote 02\L02-23 3capt V7800LGPANSVHDMI.mp4", format="YUV420P8", fpsnum=0) #\ cache=true, cachefile="source.lwi" seek_mode=0, seek_threshold=10, #\ dr=false, fpsnum=0, fpsden=1, repeat=false, dominance=0, #\ format="YUV420P8", decoder="", prefer_hw=0, ff_loglevel=0) a = LWLibavAudioSource("D:\Bolshoi\Lote 02\L02-23 3capt V7800LGPANSVHDMI.mp4", stream_index=-1, cache=true, \ av_sync=false, layout="FL+FR", rate=0, decoder="") Source=AudioDub(v,a)
It had a small audio delay during the whole video. But it ran with the correct time of 1 hour and 42 minutes.
I believe I am not adjusting the settings correctly for my video, so I will share below the MediaInfo with more information. Thank you so much for the recommendation and help!
General
Complete name : D:\Bolshoi\Lote 02\L02-23 3capt V7800LGPANSVHDMI.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom)
File size : 3.61 GiB
Duration : 1 h 42 min
Overall bit rate : 5 052 kb/s
Encoded date : UTC 2023-03-06 13:06:32
Tagged date : UTC 2023-03-06 13:06:32
Video
Format : AVC
Format profile : Main@L3
Format settings : 2 Ref Frames
Format settings, CABAC : No
Format settings, Reference : 2 frames
Format settings, GOP : M=3, N=30
Codec ID : avc1
Source duration : 1 h 42 min
Bit rate mode : Variable
Bit rate : 4 725 kb/s
Maximum bit rate : 5 000 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 59.529 FPS
Minimum frame rate : 4.286 FPS
Maximum frame rate : 60.000 FPS
Original frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.230
Stream size : 3.37 GiB (94%)
Source stream size : 3.37 GiB (94%)
Language : English
mdhd_Duration : 6130584
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 320 kb/s
Nominal bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 234 MiB (6%)
Source stream size : 234 MiB (6%)
Language : English
mdhd_Duration : 6130594Last edited by NLP; 7th Mar 2023 at 19:16.
Variable frame rate is your problem. It must be converted to constant frame rate for AviSynth. Try:
Code:v = LWLibavVideoSource("D:\Bolshoi\Lote 02\L02-23 3capt V7800LGPANSVHDMI.mp4", format="YUV420P8", fpsnum=60000, fpsden=1001)
Hi Jagabo,
When I run the script in 30,000 it works with the old LSMASHSource.dll version of 07/20/2020 but with the new version of 02/19/2023, it does not work.
Unfortunately, I have to use 60,000 as my various VHS tapes are very oxidized and they have many horizontal lines.
Moreover, I'm using 60,000 because the tracking of the image has better quality and especially because the speed of the video images is fast. I mean, the videos show people moving a lot cause they are all about ballerinas dancing in dance events.
Thanks in advance for your help!
Code:v = LWLibavVideoSource("D:\Bolshoi\Lote 02\L02-23 3capt V7800LGPANSVHDMI.mp4", format="YUV420P8", fpsnum=0) #\ cache=true, cachefile="source.lwi" seek_mode=0, seek_threshold=10, #\ dr=false, fpsnum=0, fpsden=1, repeat=false, dominance=0) #\ format="YUV420P8", decoder="", prefer_hw=0, ff_loglevel=0) a = LWLibavAudioSource("D:\Bolshoi\Lote 02\L02-23 3capt V7800LGPANSVHDMI.mp4", stream_index=-1, cache=true, \av_sync=false, layout="", rate=0, decoder="") AudioDub(v,a)
MediaInfo details of the last video:
General
Complete name : D:\Bolshoi\Lote 02\L02-23 3capt V7800LGPANSVHDMI AVDPTL.avi
Format : AVI
Format profile : OpenDML
File size : 38.9 GiB
Duration : 1 h 41 min
Overall bit rate : 54.9 Mb/s
Writing library : VirtualDub2 build 44282/release
Video
Format : Lagarith
Codec ID : LAGS
Bit rate : 53.4 Mb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate : 60.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 2.574
Stream size : 37.8 GiB (97%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate : 1 536 kb/s
Bit depth : 16 bits
Stream size : 1.09 GiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 17 ms (1.00 video frame)
Interleave, preload duratio : 500 msLast edited by NLP; 10th Mar 2023 at 09:11.
You can use AudioTrim() to advance the audio before joining the audio and video, or Loop() to delay the video:
Code:AudioDub(v, a.AudioTrim(1.5, 0)) # remove 1.5 seconds of audio
Code:AudioDub(v, a.DelayAudio(1.5)) # delay audio by 1.5 seconds
You can use Loop() to delay the video:
Code:AudioDub(v.Loop(int(1.5 * v.framerate),0,0), a) # repeat frame 0 for 1.5 seconds
Frame doubling
By timsky in forum Video ConversionReplies: 2Last Post: 18th Aug 2022, 15:47 -
Deinterlacing: "Duplicate framerate" seems to be doubling twice
By The Pack Rat in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2022, 15:44 -
Bob deinterlacing in AviSynth without doubling the frame-rate?
By orion44 in forum Video ConversionReplies: 11Last Post: 6th Dec 2021, 00:44 -
DGIndex demuxed video incorrect lenght
By maudit in forum DVD RippingReplies: 2Last Post: 19th Nov 2021, 10:40 -
QTGMC Doubling Frames Instead of Interpolating?
By LucasAuraeius in forum Newbie / General discussionsReplies: 15Last Post: 25th May 2019, 14:00
