Hi all.
I now have multiAVCHD working as I would like. Pretty stable and all functions working.
My setup includes the LAVFilters instead of ffdshow. However, I did have to disable LAVSplitters and install Haali Splitter
due to an issue with the chapter preview displaying a grey frame every now and then. Haali solved this.
One problem I have never been able to solve, regardless off the endless filter splitter combinations I tried, is with motion
background menus. The output always displays ghosting when there is noticeable movement. I will probably never have
much movement in the background, but tests suggest background encoding is not working at the best quality when motion
is selected.
The image below shows an example of this, above original. This is a particularly bad frame, but it does appear throughout
most of the background menu output to some degree.
Note: Main video/audio (.264/AC3) is not encoded.
Any ideas?
[Attachment 69601 - Click to enlarge]
Results 1 to 1 of 1
multiAVCHD Option 'Create top menu' is not working anymore.....
By NeroWolfe in forum Authoring (Blu-ray)Replies: 8Last Post: 28th Jan 2023, 10:20 -
Staxrip Encoding Issue
By deepfrayder in forum Video ConversionReplies: 12Last Post: 1st Nov 2019, 03:10 -
multiAVCHD menu
By pepegot1 in forum EditingReplies: 0Last Post: 25th Oct 2018, 19:09 -
MultiAVCHD blu-ray chapters menu problem
By Ghjklbnm in forum Authoring (Blu-ray)Replies: 1Last Post: 20th Oct 2018, 10:02 -
Help - Blu Ray Authoring with multiavchd issue
By sapruitt in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Mar 2018, 12:05
