I used to make ordinary Blu-rays in 1080P, and I can make Blu-rays with menus. Now I want to upgrade to 4K UHD, but I can’t find cheap UHD authroing software that can make menus. What software do you use?
Results 1 to 9 of 9
what do you call "cheap"?
and what do you expect from the menu?
Is 500 EUR for https://www.videohelp.com/software/BD-Wizard cheap? -
Last year, someone claimed to have created a playable UHD Blu-ray disc using Handbrake to encode the video and audio to comply with the UHD Blu-ray spec plus BD Rebuilder to author it with a simple menu and finally burned the resulting files and folders to disc using ImgBurn. See https://forum.videohelp.com/threads/406115-It-s-2022-What-are-the-free-or-cheap-option...e2#post2662590
Unfortunately, he never posted detailed instructions, so you will have to figure out the details yourself. Also, if you choose to use BD-XL media for burning your discs, most UHD Blu-ray players can only play the first 2 layers, if they can play that type of media at all. See https://forum.videohelp.com/threads/388243-BluRay-Player-with-BDXL-SupportIgnore list: hello_hello, tried, TechLord, Snoopy329 -
I use Yuhan 4K UHD Creator(https://yuhanmedia.com/), not expensive, you can try it.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 2Last Post: 15th Jul 2023, 17:51 -
UHD to Blu-ray Bitrate?
By kpic in forum Authoring (Blu-ray)Replies: 9Last Post: 5th May 2021, 11:59 -
UHD Blu Ray Spec
By premiumcapture in forum Authoring (Blu-ray)Replies: 3Last Post: 13th May 2020, 22:04 -
Rip Blu-ray and UHD Movie
By Roosvelt in forum Blu-ray RippingReplies: 39Last Post: 18th Nov 2019, 16:12 -
Ripbot264 Convert UHD Blu-ray 4k to Blu-ray 1080p
By microhunt in forum DVD RippingReplies: 0Last Post: 23rd Dec 2018, 12:12
