I'm playing with VLC player, how you know I resize the video?
Results 31 to 33 of 33
I'd suggest the OP look at HCbatchGUI which is a batch-enabled front end for HCEnc. it allows you to encode the audio from your file(s) to ac3 and then mux the resulting .m2v and .ac3 files into .mpg files as part of the batch process. You can either config each job separately, or save as templates to re-use. (The version of HCbatchGUI that is available here doesn't use the latest version of HCEnc - yes, I know even the newer version is still pretty old! - so you can just replace the older HCEnc .exe file with the more recent version - don't forget to rename it to match the file it's replacing.)
"Well, my days of not taking you seriously are certainly coming to a middle." - Captain Malcolm Reynolds
Using TMPGEnc Master Works 7 to encode DV-AVI to mpeg2......Best settings.
By Purple2112 in forum Video ConversionReplies: 112Last Post: 12th Jun 2022, 15:20 -
I have mkv files( mpeg2) how i can put them back dvd without re-encode
By GamlaGubbe in forum Authoring (DVD)Replies: 2Last Post: 11th Oct 2021, 16:15 -
how to force ffmpeg to encode mpeg2 interlaced ?
By hydra3333 in forum Video ConversionReplies: 19Last Post: 25th Jun 2021, 07:22 -
Encode closed captions embedded into MPEG2 video?
By Tanz76 in forum SubtitleReplies: 5Last Post: 19th Apr 2020, 15:24 -
Help converting AVI to MPEG2 with NO QUALITY LOSS (source file provided)
By Bobbo01 in forum Video ConversionReplies: 27Last Post: 28th Aug 2019, 09:11
