Ho can i find all video editors with lossless cut per search here?
The search field selection does not give the option "All Editors", only separated for codec etc.
thx
	Losless cut usually means you can only cut at the I frames. Just read through the description of the simple editors.
 This thread mentions some that ar 99 44/100% losless:
 https://forum.videohelp.com/threads/408763-Editor-that-only-reincodes-changed-parts
  Can't open Lossless Cut 3.52.0By jgg in forum Video ConversionReplies: 4Last Post: 22nd Feb 2023, 15:54
  Problem with video length using Lossless Cut to remove chaptersBy Shadybob in forum EditingReplies: 2Last Post: 22nd Dec 2021, 22:38
  Incorrect video cut timing on MKV video with lossless qualityBy may5224 in forum EditingReplies: 8Last Post: 19th Nov 2019, 16:02
  Problem with Lossless CutBy FL-Artist in forum EditingReplies: 1Last Post: 3rd Feb 2019, 10:40
  Best Lossless Codec to Pass AVI Between Different Video Editors on Windows?By pone44 in forum EditingReplies: 6Last Post: 18th Sep 2018, 14:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
