When capturing using VirtualDub AVI 480by480 yuy2- cd audio - huff codec the output file is enormously huge. A 2hour movie is around 30gigs. I'm making svcds out of these. Is there anyway that has similar quality results without having a super huge file when done? Could someone recomend some other codecs or compression techniques that would cut the output size down a little bit but have quality results?
I'm capturing to a 30gig slave drive and with the above settings cannot complete a 2hour movie.
Any tips would be greatly appreciated.
Thanks.
What about capturing using a M-JPEG codec? It is lossy but the quality is still very good depending on the level of compression. I capture 352x480 at 4:1 compression ratio (can't see much difference between this and HUFFYUV) and an hour worth of video is around 9 gig.
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 07:40 -
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 09:46 -
? Shrinking Multiple AVIs to Target Total-Size Then Joining to Originals
By Synetech in forum EditingReplies: 2Last Post: 4th Apr 2008, 22:14 -
batch convert avis to cd size
By clawg in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 13:27
