I'm ingesting old VHS tapes to my 2012 iMac via Blackmagic Intensity Shuttle.
I'm getting decent quality except I've noticed a lot of diagonal, moving striations. They're most visible over solid colors. Here's a small sample: https://vimeo.com/804117155/c252db4dbb
I'm using a Mitsubishi HS-HD2000U as my primary deck, it's going out via SVHS to a Panasonic DMRM-ES35V, which is used as a passthrough, otherwise the Intensity Shuttle drops frames like crazy. My cables are all shielded.
Any thoughts as to what is causing this and if I can clean it up at all?
Appreciate any help!
Experiment: ditch the Hd2000U and try running the tapes in the ES-35. You'll still get the TBC benefit.
Great suggestion. Looks like the striations are the same or even a bit worse just running through the ES-35.
Bummer. At least you know the Mitsi is OK. Try plugging Mitsi into the TV direct. That will confirm the tapes are OK or not.
I suspect something's wrong with either your cable or the s-video port ( bad soldering, loose pins). Other possibility : try to disable wifi if your vcr is close to the router
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
themaster1, I think you're right. The problem largely went away when I swapped the new "fancy" gold/shielded cable with my old regular s-video cable on the ES35.
It came back when I needed to use one of the new cables from the Mitsu to the Panasonic. So I'm thinking both new cables are just problematic.
Just ordered a new set. Will update you on results. Appreciate your help! -
When buying analog cables don't be fooled by the thickness, the fancy look or the high price, You want cables with coax core that are shielded to standard 75 ohms, The only way to be sure is to buy brand name old stock cables the likes of Monster cable or just use the cables that came with those devices back in the day.
Help with artifact clean up
By killerteengohan in forum RestorationReplies: 5Last Post: 20th Oct 2022, 11:55 -
Trying to clean up a PAL DVD
By TheMrDoggo69 in forum RestorationReplies: 6Last Post: 15th Sep 2022, 11:49 -
Blocky artifact clean up
By killerteengohan in forum RestorationReplies: 19Last Post: 6th Mar 2022, 09:49 -
90s Cartoon Clean-Up
By SupraGSX in forum RestorationReplies: 1Last Post: 8th Jan 2022, 22:25 -
Having trouble getting clean audio with NR
By JohnnyG in forum AudioReplies: 4Last Post: 7th May 2018, 06:06
