Results 61 to 69 of 69
When pluggin the yellow from the camcorder into the yellow of the tv, should give good picture otherwise something is wrong somewhere… then further tests are needed to rule out things.
Polaroid is not really the brand, it's Vestel, a Turkish product, also known in other countries for their tv's by Finlux, JVC, or RCA, on eBay boards are available for this model, i guess the camcorder works on other equipment normal.. concentrate first on finding a capture setup… the combo is also not a good bet to use...Last edited by Eric-jan; 25th Mar 2023 at 07:36.
You're just testing the video/lead at this point. Don't worry about audio. A normal RCA male to male lead will do. It can be one of your normal audio leads.
Just plug one end into the yellow socket on the camera and the other end into the yellow socket on the side of your TV. Make sure you select the correct input on the TV. -
It doesn't matter! It's irrelevant. Polaroid is on the side of the TV, that's all that counts.
Unable to include audio when copying 8mm to my PC from my Samsung Cam
By RocDon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Feb 2022, 09:47 -
Original file in mp4 format from Reflecta 8mm Super 8mm scanner
By Sajmon in forum RestorationReplies: 0Last Post: 27th Feb 2021, 11:56 -
Transferring 8mm cassette footage to my computer?
By maxton in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th Mar 2020, 12:12 -
TRV120 D8 cam won't play most old 8mm tapes, any recommended 8mm camcorders
By analog2digital in forum Capturing and VCRReplies: 1Last Post: 22nd Feb 2020, 11:44 -
Transferring Super 8mm to Digital with Telecine box
By VSz in forum Capturing and VCRReplies: 3Last Post: 20th Apr 2018, 04:09
