Hi. I recently had the problem of Avisynth giving an error when trying to run a SmoothFPS2 command. I solved it by installing Avisynth+ which ran the command easily. However, I find Avisynth+ a nuisance because, when looking through the preview of an edit (using MeGUI) there's usually a crash with the message 'Player error. Could not read AVS frame'.
Does anyone know the cause and cure of that error?
Alternatively, is there a way of telling MeGUI to use Avisynth rather than Avisynth+? I have both installed via the Universal Avisynth Installer so I could easily uninstall Avisynth+ but it would be nice to keep both and choose the one I want. Thank you.
Results 1 to 9 of 9
Vielen dank, LigH.de. I hadn't realised that the built-in avisynth was the + version. I gave it a try but, no, gave me the error message. The only thing I've found that handles the SmoothFPS2 command on this particular video is the Avisynth+ version from the Universal Installer.
Try using vdub2 or avspmod to preview the avs script, you might get more specific info on the error message
If you have one version of avisynth installed already, you can just swap the avisynth.dll to change versions. You can even swap between avs classic
The x64 .dll goes in the Windows/System32 folder; the x86 .dll goes in the Windows/SysWOW64 folder -
The Universal Avisynth Installer by Groucho2004 does that reliably for several different AviSynth(+) versions. Get to know it!
True, at the moment ... but not hopeless. Until it gets updated, one could try to patch it manually and still use its features rather than messing with Windows System directories. Your choice which method looks easier to you.
Everybody does this "messing with Windows System directories" for pinterf avs releases... You post at doom9, how were you updating the last few years ?!!
Some of the bug fixes were serious, others were speed improvements, but many were just "cosmetic"
Many newer plugins, scripts won't even run on r3382 or older avs+ versions . Many of dogways' functions don't run on old avs+
r3682 is the minimum requirement for things like RIFE, avs-mlrt (machine learning models, ESRGAN, real-ESRGAN are available in avisynth (!!) now trough vulkan and ncnn, albeit slower than the vapoursynth pytorch and tensorRT versions)
OP was trying to run smoothfps2, but RIFE will produce better results in most cases (but much slower). Search for my comparisons posted on mvtools2 vs. rife .
Best & easiest way to de-interlace in avisynth/MeGUI?
By WAusJackBauer in forum Newbie / General discussionsReplies: 80Last Post: 29th Sep 2022, 09:24 -
AVISynth Help: How do I upscale in MeGUI?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 12th Oct 2021, 05:45 -
AviSynth script error on meGUI
By vancew90 in forum EditingReplies: 16Last Post: 16th Jan 2019, 07:42 -
MeGUI + AviSynth 60 FP Anime Help
By SimplyDex in forum Newbie / General discussionsReplies: 20Last Post: 25th Mar 2018, 06:15 -
Getting MeGUI and Avisynth in Windows 10 to Work
By VideoFanatic in forum Video ConversionReplies: 5Last Post: 22nd Mar 2018, 18:38
