Closed Thread
  1. delete
  2. Do not send me DM's
    Dec 2021
    Tórshavn
    the source is encrypted, there is no unencrypted file on that page.
  3. Please can anyone provide the method to get the key from this site ?
    for the link above , the pssh:
    AAAAV3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADcIARIQvpoztgMLQGukt8Ip3QXSERoLYnV5ZHJta2V5b3MiEL6aM7YDC0BrpLfCKd0F0hEqAkhE
    lic url :
    https://spapi.zee5.com/singlePlayback/getDetails/secure?content_id=0-1-6z5229435&show_id=0-6-199&device_id=DN7VpF9nAiMybprjZt9e000000000000&platform_name=desktop_web&translation=en&user_language=ar,en,hi,ml,ta,te&country=LB&state=&app_version=2.54.3&user_type=guest&check_parental_control=false&ppid=DN7VpF9nAiMybprjZt9e000000000000&version=12&zgdpr=C0001,C0002,C0003,C0004,C0005&zcnstdt=&znpa=
    and even tried with this lic url:
    https://spapi.zee5.com/widevine/getLicense
    but still no luck , after doing some search i found this thread :
    https://forum.videohelp.com/threads/407477-help-in-getting-widevine-keys
    but no l3 script modified version that works with this site could be found , only the raw code of [ss]vegeta:
     # -*- coding: utf-8 -*-
    # Module: KEYS-L3
    # Created on: 11-10-2021
    # Authors: -∞WKS∞-
    # Version: 1.1.0
    import base64, requests, sys, xmltodict
    import headers_claro
    from pywidevine.L3.cdm import cdm, deviceconfig
    from base64 import b64encode
    from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt
    pssh = input('\nPSSH: ')
    lic_url = input('License URL: ')
    token = input('Token: ')
    device_id = input('device_id: ')
    def WV_Function(pssh, lic_url, cert_b64=None):
        wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic)
        challengeb64 = str(b64encode(wvdecrypt.get_challenge()),"utf-8")
        data = {"token":token,"device_id":device_id,"widevineBody":challengeb64}
        widevine_license = requests.post(url=lic_url, json=data, headers=headers_claro.headers)
        print(widevine_license.request.body)
        license_b64 = b64encode(widevine_license.content)
        wvdecrypt.update_license(license_b64)
        Correct, keyswvdecrypt = wvdecrypt.start_process()
        if Correct:
            return Correct, keyswvdecrypt
    correct, keys = WV_Function(pssh, lic_url)
    print()
    for key in keys:
        print('--key ' + key)
    i tried to change the code to pass the data like x-access-token , X-Z5-Guest-Token and x-dd-token ,but again no luck .
    So please anyone can provide the correct method or a modified version of the l3 script to work with this site ?
    Update: I found the way to get the keys.
    Regards
  4. delete
  5. Originally Posted by kartik View Post
    is there any Zee5 Streamer which can give nondrm url for zee5.com tv shows please.
    You have already been told NO, so stop asking.
  6. Originally Posted by thej911 View Post
    pssh:
    lic url :
    be9a33b6030b406ba4b7c229dd05d211:afbbeac1fb9c1d6543a0dad80119e20d
    Feb 2023
    India
    HEY,
    I NEED NONDRM URL FOR THIS LINK PLS "https://www.zee5.com/tv-shows/details/bhabi-ji-ghar-par-hai/0-6-199/anitas-photo-shoot-for-tiwari/0-1-6z5229435"
    LIKE THIS
    "nondrm url is this https://zee5vodnd.akamaized.net/hls1/elemental/hls/TVShows/Jodha_Akbar_Hindi_Ep01_Rev1...a837de965a62e5 d49493766affec758/index-connected.m3u8?hdnea=st=1667880416~exp=1667884136~ acl=/hls1/elemental/hls/TVShows/Jodha_Akbar_Hindi_Ep01_Rev1_RTR_hi_8a837de965a62e5 d49493766affec758/index-connected.m3u8*~hmac=db12997992302d15da54df90ca44f xxxxxxxxxxxxx1b64a647e404321ff"
    HOW TO GET IT PLEASE HELP.
    https://zee5vodnd.akamaized.net/hls1/elemental/hls/TV_SHOWS/AND_TV/October2022/0410202...d0597557c227db
    Feb 2023
    India
    lic url :
    # Module: KEYS-L3
    # Authors: -∞WKS∞-
    # Version: 1.1.0
        if Correct:
    print()
    for key in keys:
    Regards
    PM
