Some of my cameras output Gyroflow data to assist stabilization in post-processing.
If I use Avidemux to edit these videos, I guess the Gyroflow files become useless? Or can Avidemux edit them along with the video file?
Thanks. I don't want to do stablilization first and edit later because that would permanently damage my original files, leaving them with a second generation of compression. This would turn into 3 generations of compression after I edit my final movie, and then 4 generations with YouTube! Not good!
All I want to do is trim down my clips into the parts I want to use, leaving them otherwise untouched, with the potential OPTION to create a variety edits from them at a later date, POSSIBLY including stabilization.
I wonder if anyone with access to the Avidemux forum could please request support for GCSV file handling? Otherwise I'm going to have to bin all my Gyro files, which is a shame. -
You pay to much attention to number of generations. If you choose export codec/settings properly, that would not be a problem
If set the video and audio output to "Copy" in Avidemux then it will not reencode (compress) the data. When using "copy" mode, Avidemux will do a lossless copy of the data and just put it in whatever container that you specify. In order to not glitches in the edited output, you should choose your edit points to be on I frames only.
As mentioned above, you should do the stabilization before editing if stabilization is to be done at all.
If you are unsure if you want stabilization or not then you should do editing twice. Once with an stabilized file and again with a not stabilized file.
I am not an Avidemux expert. I am not sure if it has the ability to save all you edit points so that you can easily apply them to another file. There are other lossless editing tools that can though.
MP4 files with QT Audio fail in Avidemux
By abeelandig in forum EditingReplies: 11Last Post: 9th Nov 2023, 06:50 -
PotPlayer cannot handle 4K files
By xSnowLeopardx in forum Newbie / General discussionsReplies: 9Last Post: 26th Dec 2022, 19:43 -
error when merging files in avidemux
By Betelman in forum RestorationReplies: 0Last Post: 29th May 2019, 20:31 -
AVIdemux can't handle Opus multichannel
By bizzybody in forum Video ConversionReplies: 0Last Post: 11th Feb 2019, 15:32 -
Merge WMV files - avidemux fails
By pospiech in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2018, 14:25
