Results 1 to 10 of 10
    Feb 2023
    Germany
    Hello everyone,
    first of all I am awfully sorry if this subject should have been addressed before, but I just couldn't seem to find it using the search function.
    I am on the latest version of MPC-HC x64 (2.0.0 Jan 11 2023), using Windows 11 Home Edition, and for some reason I like it a lot better than VLC.
    But just today I wanted to watch a new MKV file which is supposed to have both German and English audio tracks.
    So I ran the file with MPC, to get no sound at all, and when I checked the audio tracks in the menu, there were no tracks displayed to choose from.
    When I play the same file using VLC, though, I do have sound and both language tracks are shown and available to choose from, and they work just fine.
    Although, when I run it using VLC, the audio track is by default set to "deactivated", but both the German and English audio tracks are visible and can be chosen.
    It is the only file so far that I ever had this issue with on using MPC, so I wonder what may be the reason for that.
    Surely looks like a codec issue, so I only just downloaded a new codec package, but it didn't change anything.
    The Codec shown for both audio tracks in the properties in VLC is ""DTS Audio(DTS)"
    When I check the file for details in MPC, in the properties it only shows video and subtitle information (but no audio), while in the media info tab, both audio tracks are mentioned.
    If any additional information is needed, please ask. I will be grateful for any kind of ideas on this issue.
    Thanks in advance and happy weekend, everybody!
  2. DECEASED
    Jun 2009
    Heaven
    plus
    1) Please tell us what MediaInfo says about the problematic file.
    2) "deactivated" tracks
    Well, VLC is designed to play "anything", no matter how broken are the files...
    OTOH MPC-HC uses LAV Filters, which normally do not tolerate borked files.
    "Programmers are human-shaped machines that transform alcohol into bugs."
    Feb 2023
    Germany
    When my VLC menu language was set to German, on playing this file and choosing Audio>Audio Track, there were three options, the first one was "deaktivieren", then "German" and "English"
    Sorry about the confusion, but I know now where that must have come from, because when I changed the VLC settings to English language just now, it didn't really say "deactivate" but "disable".
    So when I go to "Audio>Audio Track" on VLC with this file, it is set to "disable" and no sound, but I can change to one of the other two options "German" or "English" no problem.
    With MPC on the other hand, when I play the file and go to "Play", then "audio track" is already greyed out, and no audio track at all is available to choose.
    This is the media info in MPC:
    Format : Matroska
    Format version : Version 4
    File size : 7.59 GiB
    Duration : 2 h 30 min
    Overall bit rate : 7 242 kb/s
    Encoded date : UTC 2022-03-17 22:33:07
    Writing application : mkvmerge v66.0.0 ('Josie') 64-bit
    Writing library : libebml v1.4.2 + libmatroska v1.6.4
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference fra : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate : 4 221 kb/s
    Width : 1 920 pixels
    Height : 1 040 pixels
    Display aspect ratio : 1.85:1
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.088
    Stream size : 4.43 GiB (58%)
    Writing library : x264 core 164 r3094 bfc87b7
    Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : German
    Default : No
    Forced : No
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Bit rate mode : Constant
    Bit rate : 1 509 kb/s
    Channel(s) : 6 channels
    Channel layout : C L R Ls Rs LFE
    Sampling rate : 48.0 kHz
    Frame rate : 93.750 FPS (512 SPF)
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1.58 GiB (21%)
    Language : German
    Default : Yes
    Forced : No
    Audio #2
    Format : DTS
    Codec ID : A_DTS
    Bit depth : 24 bits
    Language : English
    Default : No
    Forced : No
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Duration : 6 s 256 ms
    Bit rate : 23 b/s
    Frame rate : 0.160 FPS
    Count of elements : 1
    Stream size : 18.0 Bytes (0%)
    Language : German
    Default : Yes
    Forced : No
    Menu
    00:00:00.000 : 00:00:00.000
    00:06:01.611 : 00:06:01.611
    00:08:32.386 : 00:08:32.386
    00:14:11.392 : 00:14:11.392
    00:18:53.298 : 00:18:53.298
    00:22:54.748 : 00:22:54.748
    00:29:34.230 : 00:29:34.230
    00:34:22.268 : 00:34:22.268
    00:41:27.318 : 00:41:27.318
    00:50:49.796 : 00:50:49.796
    01:00:07.061 : 01:00:07.061
    01:10:43.155 : 01:10:43.155
    01:18:20.320 : 01:18:20.320
    01:27:15.855 : 01:27:15.855
    01:38:15.472 : 01:38:15.472
    01:47:08.588 : 01:47:08.588
    01:52:52.932 : 01:52:52.932
    01:58:59.215 : 01:58:59.215
    02:05:42.618 : 02:05:42.618
    02:14:06.788 : 02:14:06.788
    02:20:56.865 : 02:20:56.865
    canada
    Uninstall mpc-hc with revo uninstaller free and then install it with the newest version.
  5. DECEASED
    Jun 2009
    Heaven
    Hmmmm......
    Is the "internal audio switcher" turned on or off ???
    Maybe you need to enable it OR disable it, depending on the case.
    FWIW, I stopped using MPC-HC some months ago because its audio switcher started to cause playback problems on my Windows 7 machine.
    Today I use only MPC-BE (often) and mpv (at times).
    Feb 2023
    Germany
    Thanks El Heggunte but playing with the audio settings (including internal audio switcher) did not help.
    This seems to be a harder nut to crack then. If you recommend MPC-BE (which I haven't heard of before), I will just give that one a try. And if nothing else works, I can still watch that tricky clip using VLC. Hope you have a nice evening and a good weekend!
    Edit:
    Just if you care to know, MPC-BE is running the file perfectly with both language tracks working perfectly. Now if it manages to handle all my other files, you probably found me my new favourite player, thank you!
  7. DECEASED
    Jun 2009
    Heaven
    Edit:
    Thanks 👍 for confirming that the problem was/is in MPC-HC itself, not in the media file.😌
    Feb 2023
    Germany
    Edit:
    Oh I thought that I had already confirmed by saying it runs fine on VLC, just the sound was set to disable when you run the file but you could easily choose either German or English language. It's just that I always preferred to work with mpc and it would have been too bad to have to go back to VLC just because of one single movie.
    But thanks a lot anyway for your effort and time, and tc
  9. hola, tuve el mismo inconveniente, les dejo la solución, solo deben reescribir el MKV con MKVToolnix y habilitar las pistas que no se ven en MPC-HC
    [Attachment 71201 - Click to enlarge]
    [Attachment 71202 - Click to enlarge]
  10. Originally Posted by cleffknight View Post
    Thanks cleffknight for the solution.
    Download MKVToolnix and remux the video file after setting the "Track Enabled flag" to Yes.
    It looks like MPC-BE can see these hidden tracks, but I'd rather keep using the same MPC-HC that I have been so I used MKVToolnix to enable the track. Whoever made the mkv file just mistakenly disabled the flac audio track.
