Anyone know why my version of OBS screen recorder produces alot of stuttering?. Using the trial version of Bandicam and set to a high quality, it produces no stuttering or frame lagging at all. I've even set the resolution lower in OBS and still produces a poor screen capture output. Settings in Bandicam are:
FPS: 25
Quality 80
Codec: MPEG4
Audio bitrate: 192
Audio codec: AAC
The same settings can be set in OBS but all I get is noticeable lagging or stuttering.
"same settings"The same settings can be set in OBS but all I get is noticeable lagging or stuttering.
Not exactly, granted.
OBS is complicated (AND bloated). If you make it use x264, be sure you choose the fastest settings, performance-wise;
for example, I-frames only, or at least no B-frames at all, only 2 or 3 reference frames, whatever."Programmers are human-shaped machines that transform alcohol into bugs." -
I've got the rate control set at CRF
CRF: 23
Encoder: x264
Rescale output: 1920x1080
Encoding format: MKV (I've heard that this is recommended)
Can't see any I frames or B frames, no idea what that is.
I think that using the resolution output set my processor can't cope with it for some reason.
I agree it is a complicated programme. -
There's a 100 fold difference in encoding speed between x264's fastest ("ultrafast") and slowest ("placebo") presets. The two programs are probably using different presets.
Does it exist a foss alternative to Bandicam or something?
By Chemist116 in forum Capturing and VCRReplies: 3Last Post: 11th Dec 2021, 13:40 -
Which is better? Wirecast or OBS?
By Truthler in forum Video Streaming DownloadingReplies: 2Last Post: 30th Jul 2021, 16:11 -
[avisynt] bandicam recordings from 50Pto25i conversion flickering artifacts
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2020, 18:56 -
Record Mugen gameplay with bandicam or any other software
By supercain in forum Capturing and VCRReplies: 2Last Post: 9th Apr 2020, 13:41 -
what screen recorder alternative to bandicam?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2020, 07:33
