Greetings.
Just recently transferred old 8mm files to digital ones using OBS Studio.
The video quality is great, but the audio has an echo where when the people are talking they repeat themselves.
Does anyone know how to fix this?
Results 1 to 9 of 9
Because OBS is a screen recording tool, not an analog tape capture software.
Why then does it have the capture card driver listed in video sources? Have you actually tried it?Originally Posted by Dellsham43
Thank you all for your help!
JAGOBO, you pointed me in the right direction. Once I switched off both the DESKTOP AUDIO and the MIC / AUX. volumes the echo stopped.
NOW, it is out of SYNC with the people speaking. Does anyone know how to correct that? -
OK folks I solved both the ECHO problem and the SYNC problem by switching to VLC Media. Only problem now is that I recorded just under 4 minutes, which resulted in a file of 1.85 GIGABYTES.
Anyone know what settings I have to change so that a MUCH smaller file is made when transferring to a digital file? -
In your compression codec(s) select a lower bitrate or a higher rate factor or quantizer.
8mm film to digital copying
By Camerart in forum Newbie / General discussionsReplies: 6Last Post: 31st May 2022, 11:55 -
Do Sony Digital 8 Camcorders Play Back 8mm as Well as 8mm Equipment?
By audioresearch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Jun 2020, 01:12 -
Looking to convert hi 8mm tapes to digital via a 2012 MacBook Pro
By Rhetro in forum Newbie / General discussionsReplies: 0Last Post: 19th Nov 2019, 09:12 -
Trying to convert old 8mm video cassettes to digital
By Billymax in forum Newbie / General discussionsReplies: 11Last Post: 16th Aug 2019, 05:19 -
Transferring Super 8mm to Digital with Telecine box
By VSz in forum Capturing and VCRReplies: 3Last Post: 20th Apr 2018, 04:09
