Results 1 to 9 of 9
  1. Most of us are using SSD for download.How do I increase buffer size to reduce read write on SSD ?
    What are the command to cache over 500mb ?
  2. Why the f**k are you using youtube-dl ?
    If you have read absolutely anything at all on here before posting you would know the answer to your own stupid question.
  3. Sorry if I had make a mistake , if I can't ask any question here , please tell me the correct section.
    I change my question again , hope someone would answer.
    Mar 2008
    youtube-dl hasn't been in use for more than a year. It was discontinued and replaced by yt-dlp which is still developed.
    Give that a try
  5. Originally Posted by davexnet View Post
    Give that a try
    I didn't know it was discontinue.I try with yt-dlp with --buffer-size 102400 but it still download with fragments ?
    Not able to find this "max buffer" comment.
  6. Post the url of the video you are trying to download and someone may help, from the address bar of page where it exists.
  7. Do not send me DM's
    Dec 2021
    Tórshavn
    Give that a try
    At a guess the "fragments" you see being downloaded and are having a bit of a panic about, are in fact normal.
    Dash streaming normally works by adjusting to bandwidth, increasing or decreasing bitrates and picture quality in relation to said bandwidth.
    Yt-dlp and a few other tools, effectively co-opt this functionality and focus on one particular stream selection either at max by default or by whatever flag the user has selected (the -f ) and recombine the stream fragments into one file when a set number are downloaded.
    There is no real need for a buffer. That's what dash-hls was introduced to do away with.
    So details here https://support.huaweicloud.com/intl/en-us/mpc_faq/mpc_08_0027.html
  8. Originally Posted by codehound View Post
    Every download , it just show a second of the fragment number increase , get deleted and continue joining them.I would like to buffer all the fragment into the ram and not to the SSD.
    Give that a try
    SSD health are base on r/w and with small segment , it need to erase the whole MLC nand again and again.
    yt-dlp , is a powerful download tools in command line but does it have a buffer to ram disk command ? I would like to cache to ram for those segment to 50mb and only write ton SSD.
    This method is much better than write and erase every block .
    Any guide for the command to do that?
  9. -o "path to RAM Disk"
