Results 1 to 18 of 18
    Sep 2010
    Argentina
    Hi guys, I have several audio tracks in AC3 format and I need to convertir it in AAC format Is there some that you can recommend?
    Thank You in advance!
    canada
    clever Fmpeg GUI.
    Sep 2010
    Argentina
    clever Fmpeg GUI.
    Thank You but is there another one? I canīt understand this one
  4. Member Skiller's Avatar
    Oct 2013
    Germany
    Belight is very easy to use for this.
    Sep 2010
    Argentina
    Thank You buddy, but I tried it and when I go encode the program ask me for two dlls, I found this dlls on internet, I put this files in same Belight directory, I go encode and nothing happens
  6. Member Skiller's Avatar
    Oct 2013
    Germany
    What are the file names of those DLLs?
    Sep 2010
    Argentina
    aac.dll and aacenc32.dll
    May 2005
    PAL User
    Audacity will open AC-3s. I just tried to "Export Audio..." an AC-3 file from a ripped DVD and it gave me the option of AAC.
  9. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    clever FFmpeg GUI, Audacity, etc... use ffmpeg libraries, so why don't use ffmpeg directly?
    https://trac.ffmpeg.org/wiki/Encode/AAC
  10. XMedia Recode. I use it for all my audio conversions.
    You can batch process too.
  11. Member Skiller's Avatar
    Oct 2013
    Germany
    I might be missing something, but when I try to import an AC3 audio file into Audacity it says it can't open AC3 and I need to convert to WAV or AIFF myself beforehand.
  12. I'm a Super Moderator johns0's Avatar
    canada
    You need to install the ffmeg addon for audacity.
    Sep 2010
    Argentina
    I tried that but I export the DTS, AC3, but when I select export in the list appears m4a (aac) is that? and if I select give me "the file will export as mono
    I donīt know after import, what to do?
    Please could you help me?
    Mar 2008
    Which version of Audacity?
  15. I'm a Super Moderator johns0's Avatar
    canada
    The ffmeg addon for audacity has to be installed to get at least stereo,in audacity edit/preferences/libraries you will find a download link.
    Mar 2008
    Also - Preferences - import/Export
    Use advanced mixing options
    May 2005
    PAL User
    Originally Posted by Davexnet
    Also - Preferences - import/Export Use advanced mixing options
    Yes, that was it.
  18. Member
    Sep 2010
    Argentina
    Thank You guys for helping me, I tried this one and works excelent
