Hi all,
I'm trying to combine about 80 .ts clips to a single MP4 file and I saw a recommendation here to use TMPGEnc, which does seem to work quite well, but when I import the clips I keep getting a confirmation dialog for each individual file (via the Source Wizard or the Add File command, doesn't matter), and it's very annoying.
I'm sure I'm missing something simple here... There must be a way to just add them all at once, no?
Any tips are appreciated!
First-time poster here, by the way. Be gentle...
Well, it doesn't do that for me... Here's a video of what I'm getting: https://drive.google.com/file/d/1BmJDcwA27N8YvsN5tIOKiL6weP8EPm9O/view?usp=sharing
Under Options/Preferences click the [Restore "Do not display this message again" Dialogue Boxes] button. You probably turned it off earlier. That should allow the "import as-is" dialogue to appear.
Adding background audio to menu using TMPGenc Authoring Works 6
By mulliganman in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Dec 2020, 08:57 -
adding pictures to imovie clips for the ipad?
By stargatesuite in forum Newbie / General discussionsReplies: 0Last Post: 24th May 2020, 00:15 -
appending video clips with sound and clips without sound
By Betelman in forum EditingReplies: 29Last Post: 8th Jun 2019, 10:53 -
max clips
By devdev in forum Capturing and VCRReplies: 0Last Post: 2nd Apr 2019, 17:58 -
[Vegas] adding an effect to a bunch of cut up clips
By rocco123 in forum EditingReplies: 2Last Post: 3rd May 2018, 14:10
