Results 1 to 10 of 10
  1. Hi. I currently use avisynth with MeGUI, my avisynth having been obtained from Groucho's Universal Avisynth Installer. I want to try Avisynth+ which is easy enough to install but my stumbling block is: what do I need to do to get MeGUI to use avisynth+ instead of the basic avisynth it's been using for years? Thank you.
    Dec 2018
    Brasil - BR
    instale essa versão: AviSynth+ 3.7.2
    https://www.videohelp.com/software/AviSynth-Plus
    Coloque os plugins "Avisynth" na pasta dessa instalação, o MeGUI vai se encarregar de buscar.
    Espero ter ajudado.
  3. DECEASED
    Jun 2009
    Heaven
    Originally Posted by orlandir View Post
    Espero ter ajudado.
    Next time please write in English.
    Unless you wish the rest of the world keeps thinking that Brazilians are the most trollish trolls ever.
    "Programmers are human-shaped machines that transform alcohol into bugs."
    Dec 2018
    Brasil - BR
    Besides "Dumb" is "Ignorant"
    Dec 2018
    Brasil - BR
    you are ignorant!
    Dec 2018
    Brasil - BR
    Maybe you don't know how to use Google to translate!
  7. Member hydra3333's Avatar
    Oct 2009
    Australia
    I do.
    No need to be testy and abusive
  8. Originally Posted by orlandir View Post
    install AviSynth+ 3.7.2. Place the "Avisynth" plugins in the installation folder, MeGUI will look for them.
    Thanks, orlandir. Presumably you mean place the avisynth+ plugins inside my MeGUI folder? That would mean MeGUI having to choose between avisynth and avisynth+. Can it do that or would I need to delete the original avisynth?
    Dec 2018
    Brasil - BR
    Yes!
    First you install AviSynth+ 3.7.2.
    Then you take the Plugins that you will use and put them inside the installed Avisynth.
    MeGUI will look for the plugins that are in that folder, it will recognize the "Avisynth" installed.
    You can also put it in the MeGUI folder.
    Then you will have to call every time you use them.
    If you don't understand, let me know and I'll try to explain it better.
    NOTE: Sometimes some plugins depend on others.
    Good luck!
    I can not speak English.
    I translate on Google.
    As much as possible I will try to help you.
    I've been using MeGUI for a long time.
  10. Gracias, that is helpful / eso es útil.
