[Attachment 69359 - Click to enlarge]
I have this one, I almost never use it, it works well, but I could never get the audio inputs to work, the installation DVDs didn't work, the drivers I found on the internet same thing, not even in Windows XP or 7.
Windows saying "This device is working properly" is almost-always meaningless and worthless."Programmers are human-shaped machines that transform alcohol into bugs." -
Just use the audio input on your sound card for audio.
Also check your recording settings in control panel in the sound section,make sure the audio input you want is chosen as default.
Did you check the sound in control panel when you were trying to use the pinnacle sound outputs?
Yes, i did all things you can imagine. What made me think is why the drivers that came with the DVD couldn't be installed, I had to search the internet for one that worked.
I only got to install the drivers only from this page: http://cdn.pinnaclesys.com/SupportFiles/Hardware_Installer/readmeHW10.htm
AJA LHe Plus Capture card options for VHS capture ?
By acusman in forum CapturingReplies: 3Last Post: 3rd Feb 2023, 15:21 -
S-VHS PCI Capture card for cheap HuffYuv CAPTURE
By Tek03 in forum CapturingReplies: 26Last Post: 24th Jul 2021, 22:45 -
Using Canon's EOS Utility to capture on screen video VS a capture card
By RoyZ7 in forum CapturingReplies: 0Last Post: 23rd Apr 2020, 07:18 -
Adding a new External Capture Card to my Hauppauge Colossus Internal Card
By MounaLafi in forum CapturingReplies: 30Last Post: 21st Feb 2019, 14:40 -
best capture card for vhs and hi8 capture
By hdfills in forum CapturingReplies: 4Last Post: 18th Oct 2018, 11:21
