  1. just downloaded a tmd movie clip(avi file),WMP, throws up the message'this format is unsupported',so far I have installed:
    3.11 alpha codec
    divx 5.01 codec
    smr codec
    All with no joy,anyone have any idea,am i missing a codec,downloaded a few of these tmd files,all give the same error mesage.........TEL
  2. FIRST try divxplayer
    If you get sound and video. Then convert it .
    But just to let you know tmd moves are usually only 20 frames per second and a vcd ntsc is 29.97 frames per second this means you will get a blotchy conversion. TRy to get movies from smr.
    Hope this helps
    VCD4ME
    We were all NEWBIES once and the only stupid question is the one that's not asked?
