I have original files from Netflix that have the command ‎ at the beginning of each line.
Is there a solution to delete this command for multi files in the batch convert tool?
thank you.
"original files from Netflix"
Nice job making it known you're violating their and our terms.
How to do batch Edit Subtitle color and Font ?
By ahmad98 in forum SubtitleReplies: 2Last Post: 4th Dec 2022, 12:36 -
Subtitle Edit 3.6.8 - Batch Convert
By metagondria in forum SubtitleReplies: 13Last Post: 5th Nov 2022, 18:01 -
Subtitle Edit - Split Long Lines in Tools menu vs. Batch Convert Option
By Verminaard in forum SubtitleReplies: 0Last Post: 13th Jul 2021, 05:55 -
Problem when batch converting subtitles using Subtitle Edit
By IdontKnow in forum SubtitleReplies: 3Last Post: 21st Mar 2021, 11:24 -
How to extract dvb subtitles from ts files using Subtitle Edit Command Line
By MounaLafi in forum SubtitleReplies: 0Last Post: 21st Jun 2019, 17:52
