I m facing an issue with this link that I can't seem to resolve.
The m3u8 display either the video track or the audio track, but never both, though they exist.
ffmpeg -re -i https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/sixplayhde/hls_short_enc_w9/NA/v...bv4/index.m3u8
ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-17ubuntu1~20.04)
configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-libfdk_aac --enable-libtheora --enable-libvorbis --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libvpx --enable-librtmp --enable-libass --enable-libfreetype --extra-libs=-ldl --enable-openssl
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
[hls @ 0x5636169f7b40] Skip ('#EXT-X-VERSION:7')
[hls @ 0x5636169f7b40] Skip ('## Just In Time Delivered by Quortex Solution')
[hls @ 0x5636169f7b40] Skip ('#EXT-X-DISCONTINUITY-SEQUENCE:0')
[hls @ 0x5636169f7b40] Skip ('#EXT-X-PROGRAM-DATE-TIME:2023-02-21T12:32:21.120000Z')
[hls @ 0x5636169f7b40] Opening 'https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/cBKaHZI/sFT0B0e/vpnjbv4/p0NFSkr/exC0ewe/v/segment_6247860.ts' for reading
[hls @ 0x5636169f7b40] Opening 'https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/cBKaHZI/sFT0B0e/vpnjbv4/p0NFSkr/exC0ewe/v/segment_6247861.ts' for reading
Input #0, hls, from 'https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/sixplayhde/hls_short_enc_w9/NA/vpnjbv4/index.m3u8':
Duration: N/A, start: 5393.431289, bitrate: N/A
Program 0
Metadata:
variant_bitrate : 0
Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Metadata:
variant_bitrate : 0
ffmpeg4 -re -i 'https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/sixplayhde/hls_short_enc_w9/NA/aHEUMcx/index.m3u8'
ffmpeg version 4.4-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 8 (Debian 8.3.0-6)
configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libaom --enable-libfribidi --enable-libass --enable-libvmaf --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libdav1d --enable-libxvid --enable-libzvbi --enable-libzimg
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
[hls @ 0x5d30b80] Skip ('#EXT-X-VERSION:7')
[hls @ 0x5d30b80] Skip ('## Just In Time Delivered by Quortex Solution')
[hls @ 0x5d30b80] Skip ('#EXT-X-DISCONTINUITY-SEQUENCE:0')
[hls @ 0x5d30b80] Skip ('#EXT-X-PROGRAM-DATE-TIME:2023-02-21T12:32:15.360000Z')
[hls @ 0x5d30b80] Opening 'https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/cBKaHZI/sFT0B0e/aHEUMcx/p0NFSkr/NA/a/segment_6247859.ts' for reading
[hls @ 0x5d30b80] Opening 'https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/cBKaHZI/sFT0B0e/aHEUMcx/p0NFSkr/NA/a/segment_6247860.ts' for reading
Input #0, hls, from 'https://origin2-6play.live.6cloud.fr/pool_u81ytesz/w9/sixplayhde/hls_short_enc_w9/NA/aHEUMcx/index.m3u8':
Duration: N/A, start: 5387.628622, bitrate: N/A
Program 0
Metadata:
variant_bitrate : 0
Stream #0:0: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp
Metadata:
variant_bitrate : 0
I put the same command on 2 different shells and on one I get the audio track, or the video one on the other..
Question: Since I have seen a site properly using this link (I had audio and video on the jwplayer webplayer) how can I use ffmpeg (or any other program ) to grab both input and output them in a single file? Doesn't work either on SMPlayer
I tried to use -analyzeduration 1000M -probesize 1000M in ffmpeg parameters but it doesn't help
Results 1 to 1 of 1
Audio track and subtitle track in DVD Styler
By JPM44 in forum Authoring (DVD)Replies: 3Last Post: 12th Nov 2022, 11:20 -
Edit Video Track Separately From Audio Track in VideoPad
By meandersleut in forum EditingReplies: 0Last Post: 12th Sep 2022, 12:11 -
Replacing video Track 0 and Video Track 1 but keeping intact complete MOV
By coudys in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2021, 10:39 -
Converting TrueHD Atmost track to Dolby Digital + Atmos track?
By illuvattarr in forum AudioReplies: 2Last Post: 21st Jul 2018, 23:09 -
Avisynth - Audio track longer than video track
By martanius in forum AudioReplies: 4Last Post: 18th May 2018, 02:13
