mp4box.exe -add "c:\path\source.mkv" "c:\path\output.mp4"
Thanks for your answer,
I installed "gpac-2.2-rev0-gab012bbf-master-x64" to make mp4box working, now it does, but I have this problem :
Track Importing MPEG-4 AVC - Width 1920 Height 1080 FPS 24/1 SAR 1/1
Track Importing PNG - Width 500 Height 375 FPS 90000/1
[FFDmx] No PTS for packet on stream 2
Track Importing EAC-3 - SampleRate 48000 Num Channels 6
[MP4Mux] Sample with no DTS/CTS, cannot add (last DTS 18446744073709551615, last size 0)
[MP4Mux] PID video1 ID 1 Sample 50 with DTS 1999 less than previous sample DTS 1999, adjusting prev sample duration
[MP4Mux] PID video1 ID 1 Sample 52 with DTS 2040 less than previous sample DTS 2040, adjusting prev sample duration
[Importer] Error importing 01.mkv9/100)
Failure while importing media: BitStream Not Compliant
Error importing 01.mkv: BitStream Not Compliant
is that something that can be fix ?
Thanks for your answer and time
kalemvar1 -
Something about the source it doesn't like.
Try running it through mkvtoolnix GUI to create another mkv,
then use that as your source in mp4box
Imgburn Command Line
By sambat in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2020, 15:04 -
Help using avidemux command line
By aspenx in forum AudioReplies: 7Last Post: 6th Aug 2020, 14:53 -
ffmpeg command line help
By njscorpion in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2019, 12:42 -
Can i mux or remux 4K UHD ?
By ningnong132 in forum Authoring (Blu-ray)Replies: 7Last Post: 5th Dec 2018, 17:40 -
vidCoder command line?
By Cazz in forum Video ConversionReplies: 0Last Post: 13th Nov 2018, 16:38
