I'm having conversion issues again with Any Video Converter. I cannot find the transcode log file in program files or the user folders.
Results 1 to 13 of 13
Windows 10, MPC-BE
The log (avc.log) is saved in the \data sub folder of the AVC main directory in either \program files, \program files(x86) or your portable location
if you're using that -
It was in roaming. Can you tell me what this means?
HTML Code:[2023-02-17 17:52:55,862] INFO main : --------------------------------------------------------------------------- [2023-02-17 17:52:55,862] INFO main : Logger initialized. [2023-02-17 17:52:55,862] INFO main : Windows Version Information: [2023-02-17 17:52:55,862] INFO main : Major Version = 10 [2023-02-17 17:52:55,862] INFO main : Minor Version = 0 [2023-02-17 17:52:55,862] INFO main : Build Number = 19044 [2023-02-17 17:52:55,862] INFO main : Platform Id = 2 [2023-02-17 17:52:55,862] INFO main : Version = [2023-02-17 17:52:55,862] INFO main : Windows 10 [2023-02-17 17:52:55,885] INFO EnumSystemVideoCards : Enumerator system video cards... [2023-02-17 17:52:56,147] INFO EnumSystemVideoCards : Video controller: [1, NVIDIA GeForce RTX 3060] [2023-02-17 17:52:56,147] INFO IsNvencAvailable : Loading [url=https://www.videohelp.com/software/NVEnc]nvenc[/url] functions... [2023-02-17 17:52:56,148] INFO IsNvencAvailable : Nvenc version 11.1 [2023-02-17 17:52:56,178] INFO IsNvencAvailable : Nvnec available, devices: 1 [2023-02-17 17:52:56,178] INFO check_component_available : Loading library amfrt32.dll... [2023-02-17 17:52:56,179] INFO check_component_available : VCE: Load Library amfrt32.dll Failed [2023-02-17 17:52:56,179] INFO check_component_available : Result: 1 [2023-02-17 17:52:56,179] INFO IsQsvAvailable : Checking Intel Qsv... [2023-02-17 17:52:57,176] INFO IsQsvAvailable : Intel Qsv H264 encoder : 0. [2023-02-17 17:52:57,200] INFO CVideoConverterDlg : Finding register name/code... [2023-02-17 17:52:58,084] INFO CVideoConverterDlg : Register name: CracksHash [2023-02-17 17:52:58,084] INFO main : win_sparkle_init. [2023-02-17 17:52:58,126] INFO main : SQLite version: 3.29.0 [2023-02-17 17:52:58,129] INFO CVideoConverterDlg : Version : [url=https://www.videohelp.com/software/Any-Video-Converter-Free-Version]Any Video Converter[/url] Ultimate 7.1.6 [2023-02-17 17:52:58,373] INFO CVideoConverterDlg : Internet connection available, checking module version... [2023-02-17 17:52:58,373] INFO CreateAVCDownloader : Create downloader object, output folder: C:\Users\kraco\Onedrive\Desktop [2023-02-17 17:52:59,904] INFO CDownloaderImpl::GetYoutubeDLVersion : Download engine version: 2022.05.18 [2023-02-17 17:52:59,904] INFO CheckModuleVersionThread : Checking module upgrade version... [2023-02-17 17:52:59,904] INFO CheckModuleVersionThread : Downloading [url=https://www.videohelp.com/software/yt-dlp]yt-dlp[/url] version file C:\Users\kraco\AppData\Roaming\Anvsoft\Any Video Converter Ultimate\yt_ver.ini... [2023-02-17 17:52:59,904] INFO CCheckUpdateDlg::GetFile : Downloading file from url: [url]http://update.any-video-converter.com/ver_yt-dlp.ini[/url] [2023-02-17 17:53:02,087] INFO check_component_available : Loading library amfrt32.dll... [2023-02-17 17:53:02,087] INFO check_component_available : VCE: Load Library amfrt32.dll Failed [2023-02-17 17:53:02,087] INFO check_component_available : Result: 1 [2023-02-17 17:53:02,087] INFO check_component_available : Loading library amfrt32.dll... [2023-02-17 17:53:02,087] INFO check_component_available : VCE: Load Library amfrt32.dll Failed [2023-02-17 17:53:02,087] INFO check_component_available : Result: 1 [2023-02-17 17:53:30,084] INFO main : Logger uninitialized.
Windows 10, MPC-BE -
It looks like it's enumerating the acceleration options and looking for updates
I managed to sort of find the issue. It converts fine, but when I add a subtitle, it immediately fails. It's weird because I never update anything.
Try adding a different subtitle to make sure it's not the sub.
Also, I tried the release of Xmedia Recode that is current today, 3.5.7.3, and it finally seems to work.
Perhaps give it a try, there's a portable version -
I've no idea you'll have to try it. Some more info about ASS subtitle options here
https://forum.videohelp.com/threads/401033-Subtitle-Edit-keeping-ass-font-styles -
i think it might work, but where is the setting to change the video dimensions?
The converted video works in windows, but cannot play on the PS3. Additionally I prefer hardcoded subtitles. Looks like AVC is the only way to convert and hard encode ASS subs. Thank you for your help.
It can certainly burn them in, whether the program has all the adjustments you need, you'll have to look.
Instead of the susbtitle tab I used filter/subtitles
Video8 to digital conversion issues
By Am1td in forum Capturing and VCRReplies: 5Last Post: 29th Jul 2021, 07:36 -
FLV File Conversion Issues
By vaylie in forum Newbie / General discussionsReplies: 3Last Post: 25th Jul 2020, 00:23 -
A/V Switcher - Issues?
By Smack2k in forum Capturing and VCRReplies: 0Last Post: 4th Dec 2019, 13:04 -
Toast 18 issues
By kevin shaw in forum Newbie / General discussionsReplies: 0Last Post: 4th Nov 2019, 05:04 -
Help! - Conversion issues
By AzureRathalos97 in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2018, 11:12
