Results 1 to 9 of 9
    Aug 2006
    I have a .ass subtitles file which appears to be using the Tahoma font.
    I have Subtitle Edit but I can't see where to override the font of the subtitles file. In fact, I can't even see anything in the .ass file which is specifying a font.
    I'd like to change it to Arial and make it a bit smaller.
    Note: I use VLC as my media player.
    Thanks.
    canada
    Go to options/settings/appearance.
    Aug 2006
    Thanks - tried that but doesn't seem to modify the .ass file?
  4. Member Skiller's Avatar
    Oct 2013
    Germany
    Press Ctrl and S together to save.
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Take a look at Aegisub it gives you all the options for .ass subs
  6. Select format 'Advanced Sub Station Alpha' and then 'Styles'
    'Image
    [Attachment 69282 - Click to enlarge]
  7. ASS subs are plain text. You can open them in any text editor (Notepad) and change the font name. For example:
    [V4+ Styles]
    Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding
    Style: Default,Comic Sans MS,28,&H00FFFFFF,&H0300FFFF,&H00000000,&H02000000,-1,0,0,0,100,100,1,0,1,2,0,2,40,40,25,1
    Style: Lyrics JPN,Faxfont Tone,40,&H00FFFFFF,&H000000FF,&H00000000,&H501D0032,0,0,0,0,100,100,0,0,1,0,0,8,0,0,10,0
    Style: Lyrics ENG,Faxfont Tone,36,&H00FFFFFF,&H000000FF,&H00000000,&H501D0032,0,0,0,0,100,100,0,0,1,0,0,2,0,0,6,0
    Style: Title,Faxfont Tone,55,&H00FFFFFF,&H000000FF,&H28616161,&H28E0E0E0,-1,0,0,0,100,100,0,0,1,0.5,0.1,2,10,10,20,1
    Style: Credits ENG,Faxfont Tone,42,&H00FFFFFF,&H000000FF,&H00000000,&H501D0032,0,0,0,0,100,100,0,0,1,0,0,8,0,0,0,0
    You can set the font size there too.
    Jul 2011
    Denmark
    If you use "Advanced Sub Station Alpha" in SE, you should use "mpv" as video player in order to get an accurate video-with-subtitle-preview.
  9. Load aa sub into Subtitle Edit
    Click on Capital Red "A" in toolbar
    No need for Aegisub
    You just need to know where to look
    P.S. I use both Aegisub & Subtitle Edit ... hope this helps
