can anyone tell me the fastest and the best programme to convert dvd to vcd please help :)
plenty of guides for ripping dvd to vcd can be found here:
http://www.vcdhelp.com/dvdripping.htm -
hi Sandra. i use Sefys guide. smartripper to rip, dvd2avi to make the d2v and audio files, plug those into tmpeg for encoding and nero to burn with. pretty straightforward and easy once you learn the programs. i been doing this about a month and have had some good results. there are a few people here that have posted their tmpeg templates and they work really well. i use Kwags vcd template myself, then modify it depending on the movie. you'll learn which settings effect what by reading this forum, asking ?s, and by doing. good luck.
Hi Sandra,
I suggest you first try using the Classical Newbie Guide v2.0, it will be easier to begin with, and if you feel like you are upto it, you can use the Complete Guide
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
converting vcd to DVD/blu-ray with upscale
By KePadma in forum Video ConversionReplies: 1Last Post: 18th Nov 2010, 15:13 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 15:00 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Poorly sized video on converting VCD to DVD
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2007, 01:39
