Hi... I have some m720p movies and I like how they are in good quality and low bitrate.
With mediatab, I extracted this line:
Encoding settings : cabac=1 / ref=12 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=17 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=12 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2222 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Please can you write me the exact line code for ffmpeg, or can you help me to understand this line?
Results 1 to 16 of 16
Selur had some tool available that suppose to do exactly that. So you might google it.
But understand, when encoding a video, you could have some filters involved before entering ffmpeg, even in a subtle way, like denoiser etc., so encoding is less bitrate hungry. That preprocessing is not reflected in that text. -
That's close to the veryslow preset with a few modifications. But just because a particular video looks good at those settings doesn't mean your video will look just as good. Modern clean animation may look good. But shaky, noisey, flickery, handheld camcorder video will look terrible.
Also be aware that those settings will not play properly on many standalone players. For example, Blu-ray doesn't support 12 reference frames, and 12 b-frames.Last edited by jagabo; 16th Feb 2023 at 17:43.
I have tried the software. At the end i read these lines:
Warning: a modded version of x264 was used to create this file.
The following entries got ignored:
rc=2pass since rc does not hold any useful info
filler=0
Where is this modded version of x264. Are there multiple versions?
It's possible to search for the x264 modded version in mediatab? -
Yes, that is r2901 . It's not a custom build. It's 5 years old - 18-Jan-2018
You will get similar results if you use one slightly newer or older in terms of the encoder only (not the filtering). Nothing has changed much in the last 10 years in terms of quality for x264, mainly just compatibility fixes, arm instructions etc..
https://download.videolan.org/x264/binaries/win64/
https://download.videolan.org/x264/binaries/win64/x264-r2901-7d0ff22.exe -
Latest versions are here: https://artifacts.videolan.org/x264/release-win64/
Warning! I'm baaaaaaaaack -
Ok, In Staxip I selected x264 and tweaked it, like the line from Mis2x264. Now, please can you reccomend me a downsizer from 1080p to 720p. Usually, I use Spline64, but I don't know if this is the best downsizer for movies. Please can you suggest me the best downsizer for movies? thanks.
There is no best resizer for all situations. Just different resizers for different situations. If your source is very sharp downscaling with a sharp resizer like Spline64 or Lanczos will create oversharpening halos and buzzing details. A less sharp resizer will reduce those problems. If the source isn't so sharp a sharp resizer may help accentuate small details and sharpen edges.
Ok, but in my case, I have to downsize some 1080p bluray rip to 720p. I think all the bluray are sharpened enough, and for this reason probably Spline64 is excessive. Is Spline32 a better choice for my case or do you have other suggestions? Let me know
Another question is, how work Hardware Encoder. I can't find answers or documentations about this resizer that is present in Staxrip. The problem is to understand how it work.
How can I obtain constant framerate in Staxrip. Anytime that I convert a video, this goes from constant to variable.Last edited by salvo00786; 17th Feb 2023 at 15:20.
Hi... Extract settings from video
By salvo00786 in forum Video ConversionReplies: 1Last Post: 16th Feb 2023, 12:20 -
What's the code to extract this video?
By aruwin in forum Video Streaming DownloadingReplies: 14Last Post: 23rd Sep 2022, 08:46 -
Extract avidemux encoding settings from existing video file
By cristian3095 in forum Video ConversionReplies: 0Last Post: 3rd Oct 2019, 11:49 -
Extract video file from youtubedl ?
By PowerFalcon in forum Video Streaming DownloadingReplies: 12Last Post: 17th Oct 2018, 20:46
