Hello, I've a file from my friend, and when I play on Media Player Classic, it can't play and MPC says error:
When I checked on Mediainfo, it says this:HTML Code:LAV Splitter Source (internal)::Video Media Type 0: -------------------------- Video: 640x360 29.97fps 433kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: Unknown GUID Name {CE9C899E-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 0 bTemporalCompression: 1 lSampleSize: 1 cbFormat: 134 VIDEOINFOHEADER: rcSource: (0,0)-(640,360) rcTarget: (0,0)-(640,360) dwBitRate: 433433 dwBitErrorRate: 0 AvgTimePerFrame: 333667 BITMAPINFOHEADER: biSize: 86 biWidth: 640 biHeight: 360 biPlanes: 1 biBitCount: 24 biCompression: biSizeImage: 691200 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0 pbFormat: 0000: 00 00 00 00 00 00 00 00 80 02 00 00 68 01 00 00 ...........h... 0010: 00 00 00 00 00 00 00 00 80 02 00 00 68 01 00 00 ...........h... 0020: 19 9d 06 00 00 00 00 00 63 17 05 00 00 00 00 00 .......c....... 0030: 56 00 00 00 80 02 00 00 68 01 00 00 01 00 18 00 V......h....... 0040: 9e 89 9c ce 00 8c 0a 00 00 00 00 00 00 00 00 00 ........... 0050: 00 00 00 00 00 00 00 00|01 42 e0 1e ff e1 00 1f .........B... 0060: 27 42 e0 1e 95 a0 28 0b fe 58 40 00 00 fa 40 00 'B.*(.X@..@. 0070: 3a 98 1a 30 01 6e 00 0b 70 8d ac 01 e2 85 54 01 :.0.n..p. T. 0080: 00 04 28 ce 32 48 ..(2H
I'm want to convert and watch to know that file is. Can you help me? Original file I'll give in DM when you want.HTML Code:General Complete name : D:\Compressed\SD_VIDEO\PRG001\MOV001.SD1 Format : sdv Codec ID : sdv (sdv /3gp6) File size : 40.2 MiB Duration : 10 min 0 s Overall bit rate mode : Variable Overall bit rate : 561 kb/s Encoded date : UTC 2023-02-16 11:52:36 Tagged date : UTC 2023-02-16 11:52:36 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : @L4.3 / Baseline@L3 MultiView_Count : 1 HDR format : SMPTE ST 2086, HDR10 compatible Format settings : 1 Ref Frames Format settings, CABAC : No Format settings, Reference frames : 1 frame Codec ID : Duration : 10 min 0 s Bit rate mode : Variable Bit rate : 433 kb/s Maximum bit rate : 1 499 kb/s Width : 640 pixels Height : 360 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.063 Stream size : 31.0 MiB (77%) Language : Japanese Encoded date : UTC 2023-02-16 11:52:36 Tagged date : UTC 2023-02-16 11:52:36 Mastering display color primaries : R: x=0.469820 y=0.556860, G: x=0.700420 y=0.211180, B: x=1.241960 y=0.111960, White point: x=0.626360 y=0.252900 Mastering display luminance : min: 196711.7516 cd/m2, max: 219426.9358 cd/m2 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : -40-2 Duration : 10 min 0 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 8.93 MiB (22%) Language : Japanese Encoded date : UTC 2023-02-16 11:52:36 Tagged date : UTC 2023-02-16 11:52:36
Thanks for your reply.
BD3D2MK3D: Convert 3D BDs or MKV to 3D SBS, TAB or FS MKV - Support thread
By r0lZ in forum Blu-ray RippingReplies: 562Last Post: 15th Sep 2025, 08:18 -
I want to convert SD mkv to HD mkv
By RBCC in forum Video ConversionReplies: 4Last Post: 28th Oct 2022, 09:26 -
Convert mkv with DTS HD MA to mkv with DTS core - Mac user
By bardian in forum MacReplies: 3Last Post: 9th Apr 2020, 14:30 -
How to convert.TS to .MKV with best quality ?
By Thomas91 in forum Video ConversionReplies: 4Last Post: 11th Nov 2018, 15:32 -
Freeware Software needed to convert mkv LQ to mkv HD Faaaaast
By RBCC in forum Video ConversionReplies: 8Last Post: 4th Jun 2018, 20:05
