A few days ago I recorded a TV programme on my August TV recorder (freeview). All was going well until part way through the image started to break up (probably due to the bad reception). The image just broke up for about 2 seconds and all was fine after that. But when I imported the MTS file into Avidemux, at the point where the image started to break up it left a large gap between that point and when the image corrected itself, but for some reason I couldn't removed the remaining part of the recording or save the file as a remux. I'm guessing the break up in the picture has corrupted or damaged the recording. Is there anyway of fixing this?.
TSDoctor https://www.cypheros.de/eng/tsdoc4.html?gclid=EAIaIQobChMImIz35_WZ_QIVa41oCR2iLwdNEAAY...SAAEgI8s_D_BwE prior to any processing to fix the streams.
And while you are there, you can also use its editing features, or move to AviDemux or others.
Changing/removing language informatio of tracks in TS file without remuxing
By DarkyOne in forum Blu-ray RippingReplies: 1Last Post: 8th Feb 2022, 01:33 -
By DarkyOne in forum EditingReplies: 1Last Post: 8th Feb 2022, 01:31 -
Why does remuxing from flv to mp4 increase file size?
By 90sTV in forum Newbie / General discussionsReplies: 5Last Post: 27th Mar 2020, 17:36 -
Can I create an AVCHD DVD from a .ts file without remuxing?
By Anonymous34243 in forum Authoring (Blu-ray)Replies: 7Last Post: 26th Mar 2020, 08:05 -
Remuxing with MKVToolNix removes videos' thumbnails and file properties.
By nothingness in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2018, 11:14
