I have an MP4 file which should display as 4:3 but instead default to 'widescreen', therefore everything is stretched horizontally.
I can easily change it to 4:3 by pressing 'A' when playing it using VLC, however is there a way to edit the MP4 to make it default to 4:3 ?
I see from looking at the file properties that the Frame Width under the Details tab is set to 720 so it's that which I need to change?
Use clever Ffmpeg-GUI, small, portable, no installation.
No recode will be done.
Load your mp4, click main, click change DAR, set value to 1.33 (=4:3), click change DAR.
Done.
You will find your new 4:3 mp4 into the target folder.
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27 -
.flv file video not playing, listed as frame height and width 0
By Xirix in forum Newbie / General discussionsReplies: 27Last Post: 29th Aug 2022, 11:11 -
Set a default subtitle track in a .mp4 file (with BOX4)
By Alice in forum SubtitleReplies: 1Last Post: 4th Oct 2020, 16:38 -
Change 5.1 to Stereo on MP4 video file
By tomasrage in forum Video ConversionReplies: 7Last Post: 12th Nov 2019, 15:56 -
Possible to change mp4 audio language without writing entire file again?
By JeremyBrown in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2018, 00:15
