Hi all,
I've been digitizing the old family VHS tapes, however four of them won't play audio (or will play it VERY faintly under a buzzing sound.) Hoping this forum can help me solve this mystery! Here are the pertinent clues...
-I know the VCRs are ok, because most tapes play with correct audio.
-I know the TAPES are ok, because two of the four that are having sound issues have been professionally ingested with perfect audio.
-The only tapes affected are "semi-professional." I made three full-length James Bond spoofs growing up with my dad. We overdubbed all the dialogue and music onto the master tapes. These three tapes are affected, as is a tape created by a videography company for a youth orchestra tour I was a part of.
-I know at least one of the tapes is mono, but I would expect to see audio only showing up on one channel if that were an issue.
-Changing to Hi-Fi audio levels in my capture software (using Blackmagic Intensity shuttle with Media Express/Desktop Video Setup), and adjusting the input/output gain in said software doesn't solve the problem.
-I have tried the tapes on a Panasonic DMR-ES35V, Mitshubishi HS-HD2000U and Panasonic AG-7350. (Although, I have NOT tried fiddling with hi-fi audio settings on these VCRs as I don't own their remotes.)
I'm totally stumped. Any sleuths out there have thoughts?
GREATLY appreciate any help!!
Was the audio dubbed on the mono linear track? Without any details on the technical history of the tapes I'm afraid there is nothing anyone here can do, You would have to have the remotes not just for audio but for other video settings as well, Is the HiFi logo lit when tapes are played? and lastly post a sample, Without a sample you are just wasting time typing.
For at least one of the projects I know that it was.
My current theory is that the players are trying to play the Hi-Fi stereo track, but the sound is on the mono track. I will purchase the remote for my primary player (Mitsubishi HD2000U) and change the player to mono to see if that solves the problem.
I do not see a HiFi logo lit. I do see an L and R lit up, which I BELIEVE signifies the stereo hifi channel being used. I'll double check that in the manual, though.
Sample is here:
https://vimeo.com/798914870/51c0a457b1
Appreciate your help.Last edited by ChrisStout; 2nd Mar 2023 at 15:18.
The sample you posted is a 16:9 HD video, doesn't look like a VHS capture at all.
Sorry about that, I've fixed the link.
You were right, audio was on the mono track. I bought a remote for the HD-2000U allowing me to switch audio tracks and now I'm all good. Thanks for your help! -
Why do audio sync issues happens in VHS without a frame TBC?
By bcoughlan in forum Capturing and VCRReplies: 6Last Post: 2nd Mar 2022, 17:46 -
Capture issues going from VHS to Digital: What is the likely fault?
By ShazimusPrime in forum Capturing and VCRReplies: 5Last Post: 14th Dec 2020, 14:10 -
VHS Capture Audio Hissing.
By tomjelfs in forum Capturing and VCRReplies: 22Last Post: 21st Sep 2020, 21:17 -
How to capture *UNCOMPRESSED* vhs audio+video?
By 10gigtriforce in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2020, 16:31 -
VHS Audio Issues When Using Virtualdub
By mechvhs in forum EditingReplies: 7Last Post: 24th Aug 2018, 14:25
