  1. I'm trying to download several Not protected mpd files using Yt-dlp from a text file
    like this
    yt-dlp -f "bestvideo+bestaudio" --external-downloader aria2c --merge-output-format mkv -a text.txt
    the first file will download no problem but for the second file i get an error with mpd has already being downloaded
    i thing because the first file was already the same name as mpd.mkv
    how to fix this and tell Yt-dlp to name the files as for example mpd1 mpd2 etc
  2. Read this and experiment: https://github.com/yt-dlp/yt-dlp#output-template
    This will specifically add a number to each download, like mpd00001, mpd0002, mpd00004:
    yt-dlp -f "bestvideo+bestaudio" --external-downloader aria2c --merge-output-format mkv -o "mpd%(autonumber)s" -a text.txt
  3. Thank you it works
