I have an old Panasonic M1 which doesn't get a video output from the pickup tube. The counter is on and "light" is flashing on the display, but the video behind is black with a small grey bar at the side. Is this a dead pickup tube or something else like a capacitor?
if the counter is on then its not a display issue.
before tear down, have a look through the Lens to confirm the aperture is open.
first you may check if there are some caps leakages as you thought.
then you may try to check if the voltage level is right.
You tube captions gave line length problems over and under in playback
By loninappleton in forum SubtitleReplies: 10Last Post: 7th Mar 2022, 02:24 -
ANDROID Help Downloading my ’tube Videos using VLC
By MISS CHIEVOUS in forum Video Streaming DownloadingReplies: 1Last Post: 24th Sep 2021, 16:07 -
Were there ever any flat tube (Sony Wega) professional monitors?
By lingyi in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2020, 23:03 -
Audio problems with Canon XA 10 Camcorder
By lewisbeck in forum AudioReplies: 0Last Post: 21st May 2019, 11:23 -
Best way to download U Tube videos at highest quality?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2018, 09:09
