  1. hi there,
    never used shaka, anyway i read more errors from various pages in this forum with mp4decrypt. so i would like to test shaka with N_m3u8DL-RE
    from N_m3u8DL-RE github page is only mentioned
    --use-shaka-packager
    but i need a valid example how to use it, assumed that the key is aaaaa:bbbbb
    i have the full code to use shaka
    packager-win-x64 --enable_raw_key_decryption `--keys key_id=aaaaa:key=bbbbb` stream=video,in=enc.mp4,output=dec.mp4
    but i don't think need to use all this code on N_m3u8DL-RE ...
    also from shaka page you can download < packager-win-x64.exe > but on N_m3u8DL-RE page is mentioned shaka-packager ...
    need to rename ? i'm a bit confused about all this
  2. Originally Posted by whs912km View Post
    Read this:
    https://github.com/nilaoda/N_m3u8DL-RE
    And / or use this command - its all there in clear, readable print
    N_m3u8DL-RE.exe -h
    Feb 2022
    Search the forum first!
    There are two code examples of N_m3u8DL-RE in use in the scripts in this thread https://forum.videohelp.com/threads/408557-Decryption-The-Last-Crusade
    And you are right --use-shaker-packager is enough. But be careful as you appear to have the shaka-packager binary saved as packager-win-x64. Not sure N_m3u8DL-RE will be able to find it named like that. Rename as shaka-packager and save it in your machine's PATH
  4. ok renamed as shaka-packager.exe and put on same folder with N_m3u8DL-RE i got it
    but not understand how run the right code for N_m3u8DL-RE ...
    with mp4decrypt i use simply:
    N_m3u8DL-RE -M format=mkv --key xx:xx "https://mpd"
    but still not understand how to use with shaka. sorry if i didn't understand
    Dec 2021
    england
    that what i put it on cmd
    PATH.../shaka-packager.exe in=PATH.../encrypted.mp4,stream=video,output=PATH../anyname.mp4 --enable_raw_key_decryption --keys key_id=xxxxxxx:key=xxxxxxx
    Feb 2022
    All the answers are there ... just needing to be read...
    N_m3u8DL-RE < mpd_url>- --auto-select --save-name MyVideo--save-dir ./ --tmp-dir ./ -mt --use-shaka-packager --key 33996054e18e4c4f8d4b515884ac1164:338c1b6bc23dfffd9 b74796de6a30fa2 -M format=mkv:muxer=mkvmerge
    The key difference is the mpd-url is the very first parameter. Codehound pointed you to N_m3u8DL-RE --help.
    If you had tried that the first three lines would have highlighted one error you've made.
    [Attachment 69184 - Click to enlarge]
  7. ok i've tested now
    all just wanted to know was to add to usual down code for N_m3u8DL-RE --use-shaka-packager (which i've posted on the first post)
    and rename packager-win-x64.exe (downloaded from github page) to shaka-packager.exe
    everything else is useless
    but thanks anyway for your reply. my doubt is solved
