  1. As for the title, when I capture a video streaming on VLC, I edit (cut) it on Videoredo and export it in mp4. Everytime I try to upload It to Twitter, I get an error
    To avoid this I have to re-encode It with handbrake.
    This is the Mediainfo of the exported videoredo video:
    General
    Complete name : H:\vlc-record-2023-02-11-23h44m09s-fd___0- (02).mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 8.69 MiB
    Duration : 30 s 40 ms
    Overall bit rate : 2 428 kb/s
    Writing application : VideoReDo (Lavf58.29.100)
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Format settings, GOP : M=4, N=50
    Codec ID : avc1
    Bit rate mode : Variable
    Bit rate : 2 323 kb/s
    Maximum bit rate : 2 200 kb/s
    Width : 1 024 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.158
    Stream size : 8.32 MiB (96%)
    Color range : Limited
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.470 System B/G
    Matrix coefficients : BT.470 System B/G
    Menus : 3
    Codec configuration box : avcC
    Audio
    Format : AAC LC SBR
    Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication
    Commercial name : HE-AAC
    Format settings : NBC
    Codec ID : mp4a-40-5
    Duration : 29 s 995 ms
    Duration_LastFrame : -43 ms
    Bit rate mode : Constant
    Bit rate : 96.0 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 23.438 FPS (2048 SPF)
    Compression mode : Lossy
    Stream size : 347 KiB (4%)
    Language : Italian
    Default : Yes
    Alternate group : 1
    Menus : 3
    Menu #1
    Format : txet
    Codec ID : txet
    Language : English
    Menu For : 1,2
    Menu #2
    00:00:00.000 : Chapter 1
    What could be the reason? Thank You
  2. Try to remux it only
    Ffmpeg - i input.mp4 -map 0 -c copy output.mp4
  3. Originally Posted by ProWo View Post
    Hi, thanks for Your reply. It stuck at 99% when I upload it on Twitter, this time I did the remux directly from vlc recording (So I think It isn't a videoredo issue), without going through videoredo. What settings could I use to record in a Twitter compatible way from VLC?
    Mediainfo:
    General
    Complete name : H:\vlc-record-2023-02-12-11h21m34s-fd___0-.mp4
    Format : MPEG-4
    Codec ID : isom (mp41/avc1)
    File size : 2.10 MiB
    Duration : 7 s 560 ms
    Overall bit rate : 2 330 kb/s
    Encoded date : UTC 2023-02-12 10:21:43
    Tagged date : UTC 2023-02-12 10:21:43
    Writing application : vlc 3.0.18 stream output
    Comment : QuickTime 6.0 or greater
    Video
    Format : AVC
    Codec ID : avc1
    Bit rate : 2 229 kb/s
    Height : 576 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.151
    Stream size : 2.01 MiB (96%)
    Language : English
    Audio
    Format : AAC LC SBR
    Duration : 7 s 509 ms
    Maximum bit rate : 116 kb/s
    Stream size : 86.8 KiB (4%)
    Language : Italian
  4. DECEASED
    Jun 2009
    Heaven
    Question:
    Originally Posted by origliante View Post
    Everytime I try to upload It to Twitter, I get an error.
    Answer
    Audio
    Format : AAC LC SBR
    "Programmers are human-shaped machines that transform alcohol into bugs."
