So here's the thing: I'm trying to match audio and subtitles from an older version of a movie, to the video of a new one, which differs only slightly. Normally not a problem, since I can use MKVToolnix to adjust both audio and text, but the problem is that the differences in the new video file occurs in a couple of places (maybe more, as I'm stumped at the first hurdle). Hence, even if sound and text match the video perfectly for about an hour, they then go out of sync and by the end of the movie it's all a big mess.
Is there a tool which will let me stretch or delay text and audio at several points throughout the movie?
Any audio editor (the free "Audacity" for example) can realign the audio. The method is to navigate to the point it goes out
then either edit in some silence to move the later audio along, or remove a small amount to shift the remaining audio earlier.
Should probably put up both videos on the screen side by side, and see exactly what happens when it goes out,
additional added scene, tighter editing or similar, etc,etc
You can use stackhorizontal in Avisynth to do this easily -
Super, thanks a lot! Any thought on subtitles? Do I just have to convert to .srt and manually edit the timestamps?
Use SubtitleEdit, it has a whole variety of tools to help with synchronization
Matching audio/video time in Vdub
By dave_van_damme in forum EditingReplies: 6Last Post: 3rd Oct 2021, 03:54 -
Remux matching .srt file into video file Try DVDFab Video Downloader and ri
By agon024 in forum Video ConversionReplies: 5Last Post: 26th Mar 2021, 03:57 -
Unable to extract audio data to wave file on Subtitle edit 3.5.16
By Nakasofi in forum SubtitleReplies: 1Last Post: 14th Sep 2020, 05:42 -
encoded file is slightly out of sync
By pooksahib in forum Video ConversionReplies: 5Last Post: 11th Aug 2020, 17:54 -
Zoom in effect of video in the background, in a video slightly in advance a
By HiLem in forum EditingReplies: 1Last Post: 30th Jul 2018, 20:20
