Apologies if this is the wrong subforum.
Been trying to deinterlace a VHS-C capture recorded with ffmpeg using QTGMC, specifically the "havsfunc" version for Vapoursynth, on Fedora Linux 37. For reasons I can't figure out, QTGMC causes something in my pipeline to choke and fail.
Here is my script:
I'm running it through ffmpeg with this command:import vapoursynth as vs
import havsfunc as haf
from vapoursynth import core
video = core.ffms2.Source(source='test.mov')
video = haf.QTGMC(Input=video, Preset="Slow", TFF=True)
video = haf.Deblock_QED(video, quant1=60, quant2=60)
video.set_output()
vspipe -c y4m test-deinterlace.vpy - | ffmpeg -i - -c:v ffvhuff test-deinterlaced.avi
Which gives me this error:
double free or corruption (!prev)
pipe:: Invalid data found when processing input
Here is the video in question:
Link
It does seem to be specifically QTGMC, because when I remove that line from the script, I no longer have this issue. I have also tested this on another file captured in the same manner, with the same problem.
If there's any additional relevant information I should share, please let me know, and thank you in advance for any help you can give.
Results 1 to 15 of 15
What error message does --info give for vspipe ?
Code:vspipe --info test-deinterlace.vpy -
Sounds like there is an issue with one of the filters.
Using vspipe like poisondeathray suggested might show details of what is failing exactly.users currently on my ignore list: deadrats, Stears555, marcorocchini -
To eliminate vspipe or ffmpeg, what if you just request frames, to know if it is really just some filter>
Make your file a *.py, not *.vpy and just run it.
Code:import vapoursynth as vs import havsfunc as haf from vapoursynth import core video = core.ffms2.Source(source='test.mov') video = haf.QTGMC(Input=video, Preset="Slow", TFF=True) video = haf.Deblock_QED(video, quant1=60, quant2=60) for n, f in enumerate(video.frames()): print(n, f) -
Did python specified a line for that error, if it was deblock or some of qtgmc library used?
It works for me here, but on Ubuntu, exactly the same script as you posted, using some wonderful vapoursynth package, but about 4-5 years old, I forgot name and where it was from, I remember that repo was not available anymore or updated. Not really helpful, I know. Looks like, as always, library version problem, if not a bug, that error is some library filter error.
In theory I could provide some libraries you need, if you want, but does Fedora uses same libraries as Ubuntu? And vapoursynth is R45, python using is 3.6.9Last edited by _Al_; 11th Feb 2023 at 20:41.
Far as I can tell, Python didn't get any more specific than that. Fedora is on Python 3.10, and I'm 99% sure the version of Vapoursynth I have is R61 (I compiled it from source, so I'm not using Fedora's package for it).
When I have a bit I might try spinning up a few VMs and trying this on different distros, this wouldn't be the first time I did that for something. -
Have you tried different presets in QTGMC? (different presets have different dependencies, so maybe that helps to narrow down which library is causing the issue)
So, just went through and tried all the presets. Most of the presets still failed, however "Super Fast" and "Draft" rendered successfully, and "Ultra Fast" gives this error:
File "src/cython/vapoursynth.pyx", line 2886, in vapoursynth._vpy_evaluate
File "src/cython/vapoursynth.pyx", line 2887, in vapoursynth._vpy_evaluate
File "test-deinterlace.vpy", line 5, in <module>
video = haf.QTGMC(Input=video, Preset="Ultra Fast", TFF=True)
File "/usr/lib64/python3.11/site-packages/havsfunc.py", line 1942, in QTGMC
edi1 = QTGMC_Interpolate(
File "/usr/lib64/python3.11/site-packages/havsfunc.py", line 2280, in QTGMC_Interpolate
interp = Input.bwdif.Bwdif(field=field)
File "src/cython/vapoursynth.pyx", line 1820, in vapoursynth.VideoNode.__getattr__
AttributeError: There is no attribute or namespace named bwdif -
Okay, 'Ultra Fast' fails because BWDIF isn't installed/available:
https://github.com/HomeOfVapourSynthEvolution/VapourSynth-Bwdif
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I've never seen "core dump" or similar for vapoursynth on windows.
It sounds like some Star Trek thing where they "dump the warp core"
No, on Windows you get a blue screen or some uninformative message.
Not sure what you are aiming for. If you want to reencode using ffmpeg as encoder and Avisynth/Vapoursynth for video processing does work.
If you are asking whether ont could in theory write a script, to:
a. create a Vapoursynth/Avisynth script which applies QTGMC to a source (and decodes audio to wav)
b. uses ffplay to playback that script?
Yes, I think so, assuming ffplay can play .avs/.vpy files. I doubt this will work if piping is involved anywhere.
FFmpeg-QTGMC Easy!
By Hunk91 in forum RestorationReplies: 76Last Post: 23rd May 2026, 15:45 -
Issues getting QTGMC to work in MeGUI
By Downgraded286 in forum Video ConversionReplies: 12Last Post: 22nd Nov 2022, 22:57 -
QTGMC issues on PAL capture
By agisthos in forum Video ConversionReplies: 5Last Post: 21st Apr 2021, 15:08 -
QTGMC Multithreading Issues
By yesyesnoyes in forum Video ConversionReplies: 8Last Post: 12th Dec 2020, 15:49 -
QTGMC/IVTC issues on AVISynth/AvspMod
By Fraugster in forum RestorationReplies: 33Last Post: 7th Aug 2019, 07:55
