  1. Hi ()()()
    C:\Volumes\tmp_whatsapp.avs-2
    C:\Volumes\tmp_whatsapp.avs-3
    C:\Volumes\tmp_whatsapp.avs-4
    C:\Volumes\tmp_whatsapp.avs-5
    C:\Volumes\tmp_whatsapp.avs-6
    C:\Volumes\tmp_whatsapp.avs-7
    for kindness I need a commandline to delete ALL the file that in the folder called "volumes" start naming for tmp_whatsapp.avs
    in this case I need to delete all this example files
    Is there a way? thanks
  2. Member Cornucopia's Avatar
    Yes,
    Use deltree, robocopy, powershell, etc.
    Jul 2009
    del C:\Volumes\tmp_whatsapp.avs*
  4. Note that * means any number (including zero) of any characters. Whereas ? means any one character (and there must be a character).
    So
    will delete all seven files (of that list). But
    del C:\Volumes\tmp_whatsapp.avs??
    will only delete the first six.
  5. Better practice might be to set a temp directory and all temp files put in it. Then at the end you delete that directory, simple clean up.
    set "temp_folder=D:\Temp"
    if not exist "%temp_folder%" echo creating temp folder: "%temp_folder%"& MD "%temp_folder%"
    then whatever temp file you put in there, some example
    set "mediainfo=C:\tools\Mediainfo CLI\Mediainfo.exe"
    "%mediainfo%" "video.mp4" > "%temp_folder%\mediainfo.txt"
    set info="%temp_folder%\mediainfo.txt"
    echo %info% is my temp txt file with media info parameters
    then at the end:
    if exist "%temp_folder%" DEL /F /Q "%temp_folder%"\*.*
    but double, triple check that syntax when you set that temp directory at the beginning , D:\Temp etc, so it is correct one
  6. I'm a Super Moderator johns0's Avatar
    canada
    Just highlight all the files you need to delete and delete them,no need for any cmd.
    Oct 2005
    666th portal
    can't believe that version of the "cat" is banned here...
