Results 31 to 33 of 33
Still using MPC / K-Lite Codec Pack and Xvid codec, I haven't compared using AVC yet, I really don't know how to install and capture with that codec.
[Attachment 69667 - Click to enlarge]Last edited by Litaiff; 10th Mar 2023 at 00:30.
If you truly want to improve you would listen to the great advice in this thread. You said you don't want to convert after capture, but that's a required step if you truly want the best possible results.
Capture lossless (to huffyuv for example), run a conversion after capture (I think trying handbrake is a good first step just so you can see the improvements, then move onto hybrid). It's only one extra step and you can delete the large lossless file when you are happy with the converted file.
How to analyze video?
By lv2race in forum RestorationReplies: 8Last Post: 19th Jun 2021, 19:07 -
VHS conversion
By VHStopc in forum Video ConversionReplies: 5Last Post: 1st May 2020, 09:04 -
Analyze video file properties - Ripping Question
By cr3ative in forum DVD RippingReplies: 5Last Post: 2nd Mar 2020, 20:15 -
VHS/JVC Compact VHS conversion to PC desktop
By m123caren in forum Capturing and VCRReplies: 10Last Post: 6th Jan 2020, 03:56 -
Analyze captured AVI for dropped frames
By outhud9 in forum Capturing and VCRReplies: 1Last Post: 2nd Jan 2020, 01:15
