Hi!
I have created a disc using MultiAVCHD, with three different video files. When created, I have changed the video files with those created with TsMuxer (including m2ts, mpls and clpi files), having all of them HDR10. I have then burnt the disc into a BD-R 25Gb, with menus and everything, but when I play the disc, the HDR symbol doesn't show on my TV. If I put the entire disc structure into a HDD, and then I play the files from there, the HDR is shown on the TV. I repeat, they are exactly the same files burnt on the BD-R disc. Any explanation on this? I cannot understand why this happens...
Results 1 to 15 of 15
When you play the files on hdd is it through the blu-ray player or through the tv?
The blu-ray player is an UHD player, so the problem shouldn't be there. I tested it just after watching an UHD film without any problem. I'll try playing the files through the UHD player instead the TV when attaching the HDD, just in case.
OK, I now can confirm it's something related with the burning process. I have attached the HDD to the UHB Blu-ray instead, and it shows the HDR symbol. When I play the disc again, it's not shown. I have displayed the disc info, and it says SDR instead of HDR. How can the burning process lose the HDR when burning the disc? Does it need something special for the HDR to be shown and played? Thanks in advance!
Did the files get encoded when authoring them?
Make a blu-ray structure instead.
As it is made with MultiAVCHD, I think that's the only structure it can make.
In multiavchd try unchecking 'stricter avchd folder format' in the author tab.
there's this guide if you need help - https://www.afterdawn.com/guides/archive/create_avchd_and_blu-ray_discs_with_multiavchd.cfm
HD to UHD HDR10?
By meimeiriver in forum Newbie / General discussionsReplies: 6Last Post: 5th Feb 2022, 07:21 -
Possible to convert HDR10 to HDR10+?
By ShikuTeshi in forum Video ConversionReplies: 8Last Post: 18th Jan 2022, 15:31 -
4K HDR10 > FHD HDR10 weights less than 4K HDR10 > FHD SDR ????
By bokeron2020 in forum Video ConversionReplies: 17Last Post: 17th Aug 2021, 21:47 -
HDR10 not working?
By Mikami in forum Video ConversionReplies: 7Last Post: 12th May 2019, 20:46 -
HDR10+ encoding
By namdvt in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2018, 09:46
