I'm attempting to Frameserve into CCE 2.62 and am having a monster of a time. Here's my path
*.vobs from DVD-Rip into AVI2DVD
*a2v into VFAPIConv to make .AVI file
*a2v.avi file into VDub 1.4.9 for re-size -I also add a .wav file because I heard that it won't work without a wav file included.
*Frameserved from VDub
*VDR file into VFAPIConv to make .AVI file
*the VDR.AVI file into CCE 2.62
It appears to be able to load correctly. The convert takes about 1 hour for a 2 hour movie (which seems really fast) and the VDub Frameserver window shows that no A/V frames have been served. After the convert, there is no MPV file anywhere on my system.
I've also tried
VOB --> AVI2VCD --> A2V file
A2V --> FitCD --> AVISynth Script (I use FitCD because I'm terrible at script writing, and I need to do a strange re-size)
AVS --> VFAPIConv --> .avi file
avi --> CCE 2.62
This doesn't work. When I try to run the AVS file into VFAPI the resulting ".AVI" file is empty, so when I load it into CCE, it says that it's not a valid file.
I've read the guides, searched the forums, and have tried nearly everything I can think of, but so far, I haven't had any luck figuring this stuff out. Any suggestions would be greatly appreciated (and, if possible, try to be as thorough as possible in the descriptions...I haven't yet mastered all the abbreviations and terminology! :-? )
DrC
I don't think you can frameserve directly to 2.62--do a search to try to find out.
I'm not frameserving directly to 2.62. I'm running the VDub files through VFAPI. According to Truman's guide, that's the way to get it to work on 2.62.Originally Posted by fantomlord
I suppose I will try 2.5 when I get home today.
DrC
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 20:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 18:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 22:31 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 07:01
